so what exactly will i need?
Old Jul 20, 2007 | 01:06 PM
reamo04's Avatar
alright, i want to get nitrous and get it running on kind of a budget. I am only doing a 75 shot, it will be a wet kit from HSW
the kit comes with:
10 Lb. HSW Nitrous Bottle (Black)
Pair of S.S. Quick Disconnect Bottle Brackets
PowerMax 2-Port N2O Solenoid (.078 Orifice – Up to a 200 HP Shot)
PowerMax 2-Port Fuel Solenoid (.125 Orifice – Up to a 200 HP Shot)
Nitrous Jets (75 HP, 100 HP, 125 HP, and 150 HP)
HSW Black Mamba Wet Nozzle (Anodized Aluminum)
Nozzle Retaining Nut (Anodized Aluminum)
4AN Bottle Nut (Stainless Steel)
15” (Inches) Blue S.S. Braided Hose (Solenoid to Nozzle)
15” (Inches) Red S.S. Braided Hose (Solenoid to Nozzle)
20” (Inches) Red S.S. Braided Hose (Fuel Rail to Solenoid)
16’ (Feet) 4AN S.S. Braided Hose (Main Feed Line)
Blue AN to NPT Fittings
Red AN to NPT Fittings
WOT (Micro) Activation Switch & Bracket
Arming Switch
40 Amp Relay & Harness
HSW Nitrous Pressure Gauge (Mounts directly on Nitrous Bottle)
Set of Solenoid Brackets (Hardware Included)
Electrical Pack (15’ (feet) of wire & all Electrical Connectors (Weather Tight)
I know i will need a FPSS - how do i go about hooking this up?
i will also need colder plugs, TR-6s?
brackets
purge kit - where do most of you have yours set to spray out at?
i was kind of planning on using a switch that i have to HOLD down for it to spray so would i still need a window switch?
Old Jul 21, 2007 | 12:16 PM
reamo04's Avatar
alright, after talking to a local guy, he said do not use a switch that i have to hold to spray and just use the WOT switch provided with the kit, he also said i will NOT need a windowswitch, is this true?
Old Jul 21, 2007 | 04:17 PM
2000GTP's Avatar
Get the window switch, it is a very good idea. As for the FPSS, you will need a 4AN manifold as well that will mount in series of the fuel solenoid and the Schrader valve in which you will be drawing the fuel from.
Old Jul 23, 2007 | 11:31 AM
Ray@NitroDaves's Avatar
A window switch is highly reccomended to include with your nitrous kit...it could save your motor....If you are committed to HSW i would suggest going with their brute force line as it comes with a better nitrous solenoid....the .078 is a small body solenoid and the coil to orifice ratio is a little smaller than what we like to see..
Our base kits come with a 3 port .125 nitrous solenoid and a 2 port .187 fuel
