Seprate nitrous fuel system?
Old May 4, 2004 | 10:54 AM
Slow95T/A's Avatar
Do you guys with foggers run a seperate fuel system for you N2O?
I have Aeromotive A1000 pump -10 an line to my 4port areomotive reg. and -8an line to my fuel rails.
Im going to run a small fogger 250 max more like 150-200. do you think i need a seprate nitrous fuel system?
Thanks guys
Old May 4, 2004 | 11:42 PM
speedmiser's Avatar
Assuming you've also got a high flow fuel filter and a -10line from the tank to the pump, then the pump should be able to support approx 800hp - or so Aeromotive claims. If you're going to stay below that figure then your fuel system should be able support your motor and your nitrous system.
Are you planning on a direct port system, or single or dual nozzle(s), in the airbox or boot???
If your looking at direct port, then fuel injected pressures might not be the best bet for a 100 or 150 shot. The fuel jets would be mighty tiny (unless of course you run a dry setup)
Old May 5, 2004 | 10:39 AM
Slow95T/A's Avatar
yes its a direct port but i will run seprate regulator for the n2o system
Old May 5, 2004 | 10:55 AM
Nostang 96z's Avatar
do a search under my user name....There is an in depth detailed description of what you are looking for.
Matt
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
95maroboi
Jun 7, 2015 12:18 PM
Jul 4, 2005 05:00 PM
