Is this the right pin to wire the MSD window switch
The motor is a 95 and from looking at the wiring diagram I need to tie into the red connector pin A13 tach output (white) and tie it into the window switch's white wire. Is this correct? I also have a MSD dig. 6 and was wondering if it has a tach output I can tie into instead of using the pin out of the PCM (I can't find my owners manual). Thanks
Re: Is this the right pin to wire the MSD window switch
Originally Posted by 92LT1RS
My MSD 6AL has a tach output, I'm sure the 6 Digital does too.
Jul 4, 2005 05:00 PM
