retarding timing with nitrous
What do you guys use to retard the timing for nitrous? I have tunercat, but have yet to learn to use it. I still have 5deg of knock that is mysteriously only while on the gas or at idle, so I am trying to fix that of course first. I have talked to some people and what I am hearing is to straight pull the timing in the tune instead of using an ignition box setup? Any one have luck w/ an ignition box or the tunercat?
thanks
thanks
With pulling it with a tune you will be pulling it all the time and the car wont run as well NA. With a box you will just be retarding when you are on spray. IMO this is the definate way to go. I am running the Mallory 685 ignition box and pulling 5ish i believe
Yes, it would be pulling it all the time, if I didn't have my laptop with me. Since I have my laptop I can run to the track on my normal tune, and do nothing to the tune except change the timing (-whatever degrees for 100shot, maybe 2deg?) and then that is my nitrous tune for at the track. This is what I was thinking about... still not sure.
Thanks guys for all the info, it is looking like the ignition box path will prevail. Very good points. How many degrees again? I have heard 2-3deg for every 50hp pill? So 5deg for 100shot?
mallory 685 here. i love the box its badass.
my dynotuner was aware i would be spraying, after tuning the car in, he pulled 4 degrees and there was no drop in n/a performance, so he told me not to pull any more timing, i still pull 2 degrees with a 125 shot through the mallory and so far its awesome.
