Question for LT1 ZEX Kit owners
I've been reading lots of positive posts about this kit. I have a few questions for current owners of LT1 Kits. First, did you change your injectors or are you doing ok with the stock injectors?
Second, if a solenoid goes out in the control box, can it be replaced or does the whole control box need replacing? Third, are you using a device for spark retard or are you running stock timing? Thanks. Jim |
First of all kit works awsome with stock injectors and timing. I had a 125 shot on my stock Z28 with no problems. I did go with a step colder on the plugs though. If the silinoid goes bad I beleive that the whole box needs replace but I never had any probs with mine and Is awsome looking kit with hardly anything too hard to hook up.
Stick with the zex! |
onebad97z:
Thanks for the info. Sounds like the kit I need. Thanks for the tip on the plugs. Can you tell me the part# of the plugs you use. Thanks again. Jim |
I too am still using stock injectors with not problems at all. NGK TR6s or colder plug is highly recommended as I fried 3 plugs when I tried using stock heatrange. I am using all stock timing. I do have a adjustable timing ratard in the cockpit but it is not needed with any of the shots. Mine has been problem free for the whole 9 months Ive had it. I think the whole box would need replaced...but I never looked into it so who knows.
------------------ `96 TransAm: RamAir w/ K&N filter, 125hp Zex dry kit with all the extras, 3.73 gears, McLeod StreetTwin clutch, Borla cat-back, 1le alum. driveshaft, B&M shifter, Walbro in-line fuel booster pump, Granatelli MAF, 52mm TB w/Airfoil and coolent bypass, LT4 KM + programmed computer, Accel 8.8 race wires, NGK TR6 plugs, MSD Univ. Adj. timing, Window switch, Sport-comp Nitrous, Boost, Fuel pressure gauges in center 3 vents and Air/Fuel gauge on A-pillar pod, Mobil 1 only, !CAGS, Yokohama tires, tinted windows. Low 13's on motor. Low 12's on bottle. "Lots of throttle and a backup bottle" UPDATE(8-02-02) Moser 12 bolt is here. |
