Question about Nitrous
Old Jan 19, 2003 | 08:47 PM
mnypitTA's Avatar
I have been offered a complete Nitrous setup from a 93 Z28 that was hardly used for $250. Having never really been into Nitrous or never worked with it, I have no idea what kind it is or if it will work but $250 seemed like a good deal.
Will it work on my 96 Z?
It has a sprayer or whatever it is called in the intake elbow just before the Throttle body. Does this mean anything?
John
Old Jan 19, 2003 | 08:51 PM
RacinLT1's Avatar
if it was on a 93,it will work on a 96.
Sounds like it has the nozzle (aka sprayer) which is an extremely common setup.
I would make sure everything works before venturing into a used nitrous system,and read this section for as much as you can.
Old Jan 20, 2003 | 06:07 PM
djlup's Avatar
Exclamation
Here are a few things I would look for:
Is it a Wet or Dry kit?
What size is the bottle?
Does it come with bottle mounts?
Does it come with all the braded cables?
-From the bottle to the nitrous solenoid (about 15')
-From the Nitrous solenoid to the fogger (about 3')
-From Schrader (sp) valve to Fuel solenoid (about 2') Wet Kit Only
-From Fuel solenoid to fogger (about 3') Wet Kit Only
How many solenoids does it come with?
-Only 1 = Dry kit
-2 could be Wet kit
-2 or more wet kit with a purge or remote bottle opener
What kind of Jets are included, if any?
Does it include any switches or relays?
Over all $250 for just a dry kit isn't a bad deal even if the kit only included a 10lbs bottle braded cables, solenoid and fogger.
The more you can get out of the deal the better
camaroguy50613
May 27, 2016 09:00 AM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
bandit383lt4
Dec 21, 2014 09:12 PM
Lt1son
N2O Tech
Nov 25, 2014 01:52 PM
