which plugs to use?
Old Dec 21, 2003 | 12:00 PM
Z28RV's Avatar
which plugs to use?
which plugs do i use for nitrous, i knew the answer to this a long time ago, but i decided not to go with nitrous and now i forgot...right now im running NGK TR55, which plugs do i have to use for nitrous in my 97 z28 with a stock engine?
Old Dec 21, 2003 | 02:57 PM
sniffin94's Avatar
ngktr64177
Old Dec 21, 2003 | 03:39 PM
funina91ss's Avatar
autolite 103's
Old Dec 21, 2003 | 06:09 PM
Josh-'04 GTO's Avatar
Another vote for the NGK TR6.
Old Dec 21, 2003 | 09:28 PM
kcamaro6's Avatar
3rd vote for the ngk tr6
Old Dec 22, 2003 | 12:04 AM
JustaLT1's Avatar
I like the NGK TR6's and that's what I use. However, a friend of mine uses Autolite 104's running a 175 shot and really seems to like them. Either one would work good.
Old Dec 22, 2003 | 06:39 AM
Nostang 96z's Avatar
If you can't find the NGK's you can go with AC delco R43LTS. I just put them in my car this weekend and they seem to work great. Plus they are only $1.49/ea.
Matt
Old Dec 22, 2003 | 04:03 PM
Fuels94TA's Avatar
I've ran both of them (NGK / Autolite#104) and they seem to work fine on the bottle, or just regular driving. The only problem I had with NGKs' were that if you need a replacement plug, it was hard to pick up at any local part store. With autolite's I just went into any part store, even wallmart carry them for .99 cents.
Vinny
Old Dec 22, 2003 | 06:55 PM
Derrick Redd's Avatar
Originally posted by funina91ss
autolite 103's
Ditto.
Old Dec 22, 2003 | 09:00 PM
gb95zconv's Avatar
I like the Autolite 103s with my 150 shot. They are 2 steps colder than stock ....the 104s would be one step colder. The NGK TR6s are only a 1/2 step colder than the TR55s.
Old Dec 23, 2003 | 07:58 PM
wannabeZo6's Avatar
can going to many steps colder hurt anything.....
Old Dec 23, 2003 | 08:02 PM
funina91ss's Avatar
My car ran better with the 103's NA over the 104's only thing it can do is foul the plug if it dosn't get hot enogth to burn off the carbon.
Old Dec 24, 2003 | 06:20 PM
Z28ROC's Avatar
Originally posted by Derrick Redd
Ditto.
Again
Old Dec 24, 2003 | 06:54 PM
Loadre's Avatar
I would go with either an Autolite 103/104. As said before, they're much cheaper and if you need a replacement, they're also much easier to find. Most parts chains don't carry NGK plugs.
Old Dec 24, 2003 | 09:14 PM
Tofus 93Z28's Avatar
NGK
I am a BIG fan of the TR6's..... i have been using them for 3 years....
friggin burn the strap off the mothers and still firing with no miss.......
another vote for NGK's...
