NX jetting for more than 150
First off, will my NX GM EFI kit handle more than 150? (175-200)
I'm looking to spray 75 in 1st, then another 100-125 on top of it w/a progressive controller. Am I stuck with 150 before I need to upgrade my solenoids and N2O/fuel lines?
Insight is welcome.....thanks.
Re: NX jetting for more than 150
I personally wouldn't spray more than 150 for the sake of your stock shortblock.
I might try bumping up to 175 this year, but only w/ running straight race gas. Just gotta toss in bigger jets.
You could also run a dual stage vs. a progressive controller (which are harder on the solenoids).
Thanks for the reply Joe....I'll stick with 150.
If I'm sending out the solenoids to be refreshed annually, will the progressive controller still not be recommended?
Yeah but....you have a 12-bolt
When I get my Racetronix pump in, I'll test 150 in the top of 1st and see how it does. Might have to replace these Nitto's with MT ET Drag Radials and knock on wood
PS - What fuel pump are you running?
As long as you are internally stock and running a wet kit w/ stock fuel pressure, and your fuel pump is functioning normally, your stocker is fine. I ran many bottles through my motor when it was internally stock w/ a bone stock fuel system.
When I added the ported heads and cam, nitrous along w/ it was well above what the stock pump could take. Tossed in a Walboro 255 pump, good to go. I would have bought a Racetronix pump, but honestly, as long as you aren't pushing the limits of what the pump is capable of, doesn't it really matter if you are only getting 90% of its benefit, as long as it is more fuel than you need. When I start pushing the limits more, I'll go and buy one of their harnesses.
I have a buddy w/ a built 4L60E, slightly modded 10-bolt, that has pulled a best of 10.9x @ 126.x w/ it on BFG DR's. Mind you this is a supercharged LS1 car, but the 10 bolt can take some abuse w/ an auto.
Originally Posted by Derrick Redd
I totally agree on that. Joe what was your buds 60fts.? I've been running a NX 175 shot for the last 2 years with no issues on the stock shortblock. 255 lph intank and tuning.
I've been running 73/41 jets for a little over a year on a iceman solenoid with 3an lines to a shark nozzle, I'm debating whether or not to move up to 78/44 but everyone that has talked to NX says to upgrade to 4an lines to the nozzle...
I'm not calling BS or anything... but how can a 4an hose with 3an fittings/adapters flow more? It seems to me the 3an fitting would still be the bottleneck limiting the flow... Could someone explain?
