Nx bottle opener switch ?
If you email it out can I get a copy too? I was just going to ask the same exact queston. Thanks, Alan
Alan566@mycingular.com
Sorry guys that it took me so long, been busy.
I don't have the technology here to post a pic but I can tell you.
Looking at the 6 prongs, have it pointing up so that the one prong by itself is up,that one is the black wire from the motor.Then you have two more down, the left one is negative from the battery, the right one is also negative from the battery.Then the next one down that is horizontal is 12V(Keyed).Then to the bottom two, the one on the left is red from bottle opener and the one on the right is also 12V(Keyed).
If you have any questions just ask.
That's what it looks like. The "activation" is like this
Like to add, I have the NX Switches.
the prongs look like that?
we already found that the Activation switch was made improperly. it was upside down. :/
So, I have no idea what to do now. except use a multimeter and check all the progs for pos/neg and what not. :/
Take a look on the back of the switch and if it has letters by each terminal maybe this will help. My instructions show:
Terminal A: + from battery
B: - from battery
C:- from battery
D: Black wire to motor
E: Red wire to motor
F: Wire to light terminal
I think that terminal C is the - post for wiring the light inside the switch, wire F goes to vehicle light switch.
I bought my opener used and didn't use the switch (I went with the NX switch panel). So with it here in my hand I checked it with a meter and it checks out as:
Terminal A power in and D and E to the bottle wiring. D opens, E closing.
Hope it'll work for you.
B: - from battery
C:- from battery
B: - from battery
C:- from battery
B: - from battery
C:- from battery
Maybe I didn't explain well enough.
I have the Nx switch panel activation/warmer, bottle opener/closer and the Purge.
not the stuff that comes with the items. but the WHOLE NX switch panel.
:P if that clears things up.
