Nitrous w/Propane
Old Apr 1, 2004 | 03:24 PM
andy katzelis's Avatar
Nitrous w/Propane
Anyone with any experience spraying with propane? I'd interested in some "safe side" propane jet size starting points with 50, 100, 150hp levels?
Old Apr 1, 2004 | 08:17 PM
Stephen 87 IROC's Avatar
Do you mean using propane as the NOS fuel or a propane fueled engine with nitrous added to it?
If it's a propane engine and you want to use nitrous, you need to do like alcohol racers do. The NOS setup is calibrated for gasoline. Install it like normal except you need a seperate small fuel cell and pump to inject the gasoline when the NOS is turned on. A mixture of propane and 92+ gasoline won't hurt anything.
A 1 gallon fuel cell mounted under the hood with a Holley red or blue pump with regulator is all that's needed.
Using NOS with an alternate fuel engine isn't hard. Just keep the levels within the range that you normally would use with a gas engine.
Old Apr 1, 2004 | 09:56 PM
kmook's Avatar
Advanced Tech Moderator
I'll move this to the N2o Forum. Do a search there on 'propane', you will get some good results too.
Old Apr 2, 2004 | 06:47 AM
Sorry, I wanted to use the propane as the enrichment fuel on a gasoline engine.
Additionally, thanks to Injuneer and some others I at least learned propane is already being used as a supplimental fuel.
However, in looking at the 3000 and viper websites I still couldn't seem to find jetting recomendations. I thought the advanced tech patrons could help.
Old Apr 3, 2004 | 10:28 PM
mtxpert's Avatar
This is definitely a good topic.
If I ever get my car running well again with the 396 I'd like to use propane as a supplemental high octane fuel source instead of dumping 22 gallons of 110 unleaded in the tank.
The hardest part is going to be finding a good way to store the propane.
I think that using my NOS 58MM TB is still feasible by using a standard wet nozzle with the end cut off with propane where the fuel inlet was and nitrous on the other side spraying into my dry TB.
That's just a theory of course.
Mike
Old Apr 5, 2004 | 08:41 AM
Looks like some folks are just using DOT apporoved 5lb tanks parked right next to the nitrous tank. I'll pass on that. Likely place a piece of steel between myself and the tank. Burn's arn't fun.
I modified a tank nozzle this weekend, assuming a high volume of propane will be required. I'll be ordering a solenoid this week.
However, I am still trying to finish another high priority project, and I'm trying to finish before the birth of my second daughter on June 1st. I'm using the propane project as filler work.
Looks good so far, I'll end up doing a little more research on the gas vs propane characteristics. Looks like propane is a 105 octane and has 92000 BTUs heat per pound. I'll compare with gas and nose around some more before I decide to just jet low and work my way up, maybe 50-75-100-+. Get a feel for the jetting off of the o2 numbers and reading the plugs.
By the way, unless the 105 is a motor octane number, one may be limited to under 200hp, at least by NOS's recomendations. I'd still run race gas.
I just like the dry spray, it's easy to work, easy to hide, and it is cheap to install.
I'll read some more about your awsome car, I've got some questions, but I'm a little busy today.
Old Apr 5, 2004 | 02:43 PM
Looks like propane's BTU content is about 22,000 about the same as gasoline. I was reading calories eariler. Sorry.
Old Apr 6, 2004 | 12:52 AM
CRCDUDE's Avatar
Originally posted by andy katzelis
my second daughter on June 1st. .
Congrats on #2 there Andy . Paul has a Book on alternative race fuels Authered by some Formula 1 guy. I'll try to get the name and auther for ya. It's a real good book and has all the properties and specific gravities of nearly all chemicles used in race fuels and allternatives.
you ready to run out there @ OC yet ??
We got a black TA for ay whenever your ready
Old Apr 6, 2004 | 07:43 AM
Thank you and thank you.
I'm getting the white car ready, I'll work on the firebird a little later. I have some good ideas. Propane just being one.
I really need to get the other car done, but, I picked up a solenoid last night. The curiosity is killing me.
Likely I'll start logging data and checking plugs very soon.
Old Apr 8, 2004 | 01:49 PM
I successfully bendh sprayed propane last night through a solenoid. Sounds good and really throws a flume.
I have all the hardware rounded up for the install.
Testing should begin soon.
Any one with jetting advice?
I found a starting point but no real array of levels.
Old Apr 8, 2004 | 05:33 PM
CRCDUDE's Avatar
Wink
Pilll IT till ya KILL it
I would guess 2-3 sizes more on the fuel side if it spits an sputters then she's to FAT. If it screams like the Demon posessed
Then stop and check plugs
Definatly no more than a short burst the forst few times till ya get a handle on the a/f ratio
You know the drill, if ya play MAD scientist and start mixin Hydrogen peroxide with liquid O2 then somethins gonna break.
GOOD LUCK.
Oh ya and were puttin .028's in the TA this weekend
Old Apr 11, 2004 | 05:17 AM
oil pan 4's Avatar
Are you useing an O2 gauge?
Old Apr 12, 2004 | 08:23 AM
I'll proceed with extreme caution and use the onboard O2s along with plug reading to verify correct operation.
Thanks fellas.
Old Apr 17, 2004 | 04:26 PM
smoknta's Avatar
if you guys need some more info, they have been injecting propane into diesels for years.
RUENUF
Mar 13, 2016 03:37 PM
Quickss96
Jan 29, 2016 05:56 PM
95blkss
Sep 22, 2015 03:18 PM
nd4spd200
Aug 21, 2015 09:30 AM
Steve69SS396
Track Kill Stories
Aug 17, 2015 08:48 PM
