CamaroZ28.Com Message Board
-   N2O Tech (https://www.camaroz28.com/forums/n2o-tech-23/)
-   -   Nitrous and timing (https://www.camaroz28.com/forums/n2o-tech-23/nitrous-timing-710370/)
CamaroSS30thAnn Sep 11, 2009 02:46 PM
Nitrous and timing
I i have an Lt1 with a rebuilt 350 forged rods pistons, aftermarket crank. Also the GM847 cam with ported heads and larger valves. 30#lb injectors 255lph in tank pump and the zex 125 dry shot with colder plugs etc. There are few other misc options like LT headers the normal. Car right now has a tune just to pass emissions.
My question is with a basic tune just for motor if i wanted to plug in my nitrous and run it what kind of timing should i have taken? I have the mallory box and can do it with the push of the button.
I dont have the time to get a tune right now and im just looking for maybe 2 base runs with the nitrous.
When i had the stock motor with just LTs i pulled 4 degrees of timing and it worked well.
What kind of timing should i pull now and be farely safe for a few runs?
CamaroSS30thAnn Sep 12, 2009 03:06 PM
bump
jonesy Sep 17, 2009 08:42 PM
I would still pull 4 degrees
93v8clone Sep 18, 2009 06:46 PM
where in ny are ya ?
remaxracer45 Sep 23, 2009 07:31 PM
how much n/a power would you guess that is?
CamaroSS30thAnn Sep 30, 2009 11:02 AM
buffalo and close to 400 wheel close bc of the bigger rear and tranny
