Nitrous System Wiring
Old Nov 19, 2007 | 11:27 AM
  #31
Ray@NitroDaves's Avatar
Originally Posted by lt1rx798
dave, i have the lt1 plate kit. does the "86" post on the relay need to pass through the WOT swith before going to the acc. slot on the toggle? ...or does it go straight from "86" to toggle and "85" straight to the WOT?
i didn"t get instructions, and im wiring dumb........
either will work.....
but this is how I would do it...
Old Dec 12, 2007 | 12:14 AM
  #32
transamzex's Avatar
i have 05 gto 6 spd and a zex 82026 with bottle warmer and dual purge with red leds and have everything hooked up but the bmn window switch and the relay and the fpss so if i had a diagram for that it would be so cool.
P.S. I bought the bmn/fpss from nitro daves so it's kinda like customer support--thanks in advance
Old Dec 12, 2007 | 09:13 AM
  #33
BMN window switch with ZEX controller
B will connect to the red wire on the ZEX box
FPSS will go inline on the purple wire from the BMN going to 86 on the relay
Old Dec 12, 2007 | 10:11 PM
  #34
transamzex's Avatar
thanks ray
u da man
Old Feb 15, 2008 | 08:38 PM
  #35
'94 Bad A Z28's Avatar
Originally Posted by Ray@NitroDaves
Can you show a normally open switch added in after the WOT switch so that you can get out of the kit without getting out of the throttle or disarming the kit? This way you could just let off the kit if you lost traction, but without getting out of the throttle.
So that you have arming switch------->WOT switch-------->Normally open push/hold button------->Relay------->Solenoids.
I would assume that you wouldn't have to worry about a ground on the push button switch but I am unsure about this since I have never wired a kit up like this. Just something that I want to try out on my setup.
Thanks,
Eddie
Old Feb 16, 2008 | 12:30 PM
  #36
Chopstix's Avatar
it would be a 2 wire switch that wires the same as the WOT in the diagram....just duplicate the push button inline on the wire inbetween the ACC pin on the arm switch and pin 86 on the relay
Old Feb 16, 2008 | 12:41 PM
  #37
Okay, cool, that's what I thought.
Old Feb 20, 2008 | 05:40 PM
  #38
FASTFATBOY's Avatar
I need one for :
Nos Single stage big shot plate
FPSS
microswitch activation on button
Accel 300+ with the 375+ retard box(12 volt retard activation)
Stand alone fuel system.
Purge
Activated from a Nitrous outlet ash tray switch panel
BTW dont you guys have a special going on the switch panel?
Part number NO-00-11011
Thanks guys
Old Feb 28, 2008 | 02:38 PM
  #39
Originally Posted by FASTFATBOY
I need one for :
FPSS
Purge
Thanks guys
3rd diagram in the 1st post
Old Mar 25, 2008 | 08:28 AM
  #40
N20Dave's Avatar
Hey Ray, how about one with the FJO in it. Thanks.
Old Mar 31, 2008 | 09:01 AM
  #41
2nd picture in post #2
Old Apr 11, 2008 | 06:57 PM
  #42
Zeetwentyfate's Avatar
can i get a diagram using the malory 685, im using the 2 step and window switch and need to run the step through a relay so i dont spray on 2 step haha...that would = goodbye 4th 1LE elbow
Old Apr 21, 2008 | 09:20 AM
  #43
niksmoov's Avatar
Re: Wiring for 00 Z28 w/WOT switch & Zex window switch
I'm trying to figure out how to install the Zex tration control window switch on my 2000 Camaro Z28.
I am using WOT switch to cut the nitrous on at the present time.
What I need to know is where does the green tach wire go?
Old Apr 22, 2008 | 09:29 PM
  #44
Firebird_fr3ak's Avatar
NX Wet kit with FPSS and BNM WS.
Old Jun 8, 2009 | 07:51 PM
  #45
remaxracer45's Avatar
Please help! I sent you a email Ray, no response? I have a 94 Z with a 6al a efi wet kit with your switch panel and all the accys (purge,warmer) I have a jacobs mastermind and want to hook it up right the first time, any diagram for that setup Thank You
