Nitrous ring gap
Old Jul 11, 2007 | 09:07 AM
69gto96z's Avatar
Nitrous ring gap
Anyone know where I should set my ring gap on my new motor? Stock bottom end, and it will be seeing a 100-125 shot occasionally. I have heard go a little bigger than what the factory reccomends for nitrous/FI applications, but not sure if it matters that much with such a small shot.
Old Jul 11, 2007 | 11:37 AM
quickSS's Avatar
I would keep it right at stock ring gap. The stock Mahle pistons and the new Mahle rings should work well with a 100-125hp nitrous shot. (and good tune-up).
Karl
Old Jul 11, 2007 | 11:58 AM
mike2244's Avatar
if you have a 4.00" bore then the top ring should be .020"-.022" and the bottom ring .022"-.024" that is for street nitrous.
Old Jul 11, 2007 | 01:29 PM
quickSS's Avatar
of course that's dependent upon the piston brand and ring brand and how far the 1st ring it down from the top of the piston.
for your stock piston and stock ring, I think it will be .016" top and .020" 2nd as is. But the small nitrous hits should not require a wider gap. Wider is safer though.
Karl
magman
Apr 15, 2016 03:08 AM
IndyZman
Oct 22, 2015 02:17 PM
95blkss
Sep 22, 2015 03:18 PM
mmf_1013
Sep 12, 2015 08:56 PM
blaze309
Sep 8, 2015 05:27 PM
