Nitrous Purge Question
Old Sep 24, 2004 | 09:56 AM
Mr_Bond's Avatar
Question 1: After I close the bottle, should I purge the nitrous out of the lines then, or is that a waste.
Question 2: If I don't purge, will the line hold the pressures and should I just purge when I reopen the bottle?.
Old Sep 24, 2004 | 11:05 AM
sssalah's Avatar
Re: Nitrous Purge Question
I think its better to purge to relief the pressure at the solenoid, lines and fitting. Depending on the periods between each use the pressure will be lost gradually.
Old Sep 24, 2004 | 11:31 AM
Ucantcme57's Avatar
as long as you haven't taken the bottle off, I don't think it would matter just a waste, but ricers love to purge all the time, as well as hard core drags, nx even makes a light that comes on and makes it really easy to see your purge at night.. Most always purge before a real race the rest of the time you might just put in a little more ambient air than no2, no hurt there...
Old Sep 24, 2004 | 07:19 PM
Fuels94TA's Avatar
ditto.
Old Sep 24, 2004 | 10:22 PM
Me too! When you shut the bottle valve, let the pressure out of the system with the purge. Its going to leak out anyway, evnetually. The pressure pushes the plunger in the solenoid down into the elastomeric seat. Keeping the pressure on the seat when it isn't in use can cause the seat to deform, and even tear, at least with the NOS solenoids.
Old Sep 25, 2004 | 01:52 PM
rpm4lalo's Avatar
Another vote to purge the system after you close the bottle. I always purge on unsuspecting people.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
alphaauto
Jan 23, 2015 07:42 AM
bandit383lt4
Dec 21, 2014 09:12 PM
Speeds8erM-1
Jul 18, 2002 11:36 PM
