Nitrous pistons For Lt1
Old Feb 18, 2009 | 08:40 PM
walt355's Avatar
Who makes the best bang for the buck in nitrous pistions for a Lt1 taking around a 300 shot of juice? I havent worked on mine in over a year and its time to get it back togather,
thanks
Old Feb 19, 2009 | 12:39 AM
shak180's Avatar
mahle
Old Feb 19, 2009 | 06:48 AM
rskrause's Avatar
Moderator
What CR are you shooting for? BTW, AFAIK Mahle does not make a nitrous specific piston, which you will need for a 300 shot, IMHO.
Rich
Old Feb 19, 2009 | 08:35 AM
NVetro's Avatar
walt355: For my setup I am running nitrous and in the future boost+nitrous when I get a lower CR with some larger heads. I went with a custom set of JE pistons with nitrous pins. By custom they are not the standard 4340 forged alloy, they are 2618 forged alloy which are designed for high boost and high n2o applications as there expansion rate is lower which is what u want with the added cylinder temp.
They can make them for you in any CC, I went with a -16cc 2618 forged alloy piston with nitrous pins and hellfire rings. Give a call to JE Pistons, they ran be about $1000. They also have a great tech line, call'em up :-)
Also make sure to give yourself enough piston to cylinder wall clearance
Old Feb 19, 2009 | 10:49 PM
walt355's Avatar
Im shooting for about 12:1 which would be a flat top if Im figuring right. I think I might call JE and talk to them. what about a Probe piston? Anyone usung them/
thanks fellas
Old Feb 20, 2009 | 07:17 AM
rskrause's Avatar
Moderator
thanks fellas
JE is then the right choice. They have a "heavy duty" flat top designed for nitrous/boost. You will save some $$ because it sounds like you can use a shelf piston.
Rich
Old Feb 20, 2009 | 07:33 AM
NVetro's Avatar
Rich is correct, build once...you either pay now or pay later...if you cant find a shelf nitrous 2618 alloy piston to meet your 12:1 CR then they can make you one...but like rich said you can save some coin going with a shelf piston...
But def JE, you cant go wrong.
Old Feb 21, 2009 | 08:09 AM
walt355's Avatar
OK let me ask a dumb question, what is a shelf piston?
Old Feb 21, 2009 | 08:15 AM
rskrause's Avatar
Moderator
Standard specification such that they may be "on the shelf" waiting to be shipped.
Rich
Old Feb 21, 2009 | 05:17 PM
AutoRoc's Avatar
Diamond Pistons...Ask for Mike, he can set you right up with the right piston. They are second to none in product and service.
Old Feb 21, 2009 | 10:31 PM
walt355's Avatar
Rich
i knew that, thanks
Old Feb 22, 2009 | 06:23 PM
Boostwhat's Avatar
I second diamond.... Second to none in my opinion. I ordered a custom nitrous specific set for my 383 LT and have had no problems whatsoever. Yes they were pricey, however I only wanted to do this ONE time.
Old Feb 22, 2009 | 06:58 PM
NVetro's Avatar
I've heard good things about diamond as well, i'm sure either or is a great choice. If i had to go back and do it again i would still go JE.
Old Feb 24, 2009 | 04:06 PM
bombebomb's Avatar
I went with JE for a nitrous specific piston. JE and Ross are known for being #1 in most peoples eyes.
Old Feb 25, 2009 | 09:43 PM
1982z28with18s's Avatar
My wiseco's held A LOT of nitrous(up to a 325rwhp shot), but finally died on me after the head gasket let go and it went lean one night. Not sure a custom nitrous piston(je/diamond) would've survied either, but if you want to do it right, get a true nitrous piston from diamond or je and don't look back honestly.
