Nitrous Outlet Summer Specials
Old Jun 9, 2008 | 11:48 AM
Ray@NitroDaves's Avatar
Nitrous Outlet Summer Time Special!!
Race season is here and its time for car shows, local car meets, and fun days at the race track. Be on top of your game with Nitrous Outlet!
We have put together a few special packages to help you kick off the summer with a bang!
Group 1.
LS1 or LS2 Plate special.
Your choice of a 78mm, 85mm, 90mm, or 92mm Nitrous Outlet Plate System with black 10lb bottle, Automatic bottle heater, Purge, Fuel pressure safety switch, Nitrous pressure gauge, Nitrous filter, NHRA Blow off fitting, Blow down tube and Digital dual stage window switch with built in TPS activation and gear lock out feature.
COST= 1106.00
Group 2.LT1 Plate special
Your choice of 52mm or 58mm Nitrous Outlet Plate System with black 10lb bottle, Automatic bottle heater, Purge, Fuel pressure safety switch, Nitrous pressure gauge, Nitrous filter, NHRA Blow off fitting, Blow down tube and Digital dual stage window switch with built in TPS activation and gear lock out feature.
COST= 1150.00
Group 3.
Single Nozzle special
Nitrous Outlet Single Nozzle System with black 10lb bottle, Automatic bottle heater, Purge, Fuel pressure safety switch, Nitrous pressure gauge, Nitrous filter, NHRA Blow off fitting, Blow down tube and Digital dual stage window switch with built in TPS activation and gear lock out feature.
COST= 971.05
Group 4.
This is for the guys looking for a budget set up minus a few bells and whistles with out sacrificing quality.
Brand X Single Nozzle Special
Brand X Single Nozzle System with black 10lb bottle, Automatic bottle heater, Purge, Fuel pressure safety switch, Nitrous pressure gauge, NHRA Blow off fitting, Blow down tube and Digital single stage window switch with built in TPS activation and gear lock out feature.
COST= 695.00
Group 5.
Nitrous Outlet Dry Halo system.
Your choice of the F-body or GTO dry Halo system with black 10lb bottle 860 Billet bottle bracket / Automatic bottle heater combo, Purge, Fuel pressure safety switch, Nitrous pressure gauge, Nitrous filter, NHRA Blow off fitting, Blow down tube and Digital dual stage window switch with built in TPS activation and gear lock out feature.
COST=845.00
Old Jun 24, 2008 | 12:59 AM
Nitro Dave's Avatar
This month is almost over...
Old Jul 3, 2008 | 10:23 AM
Nitro Dave's Avatar
We have decided to extend this deal until August 1st!
Aug 24, 2015 06:41 AM
MikeWhitener
Aug 2, 2015 06:17 PM
Jul 17, 2015 02:47 PM
Jul 10, 2015 02:23 PM
