Nitrous Outlet monoblade plate?
I just bought a nitrous outlet monoblade plate off a friend and I currently have a twin 58mm tb with a intake opened up for a monoblade. Will this work fine until I can get a monoblade since the intake matches the plate?
a little late but, here for the next guy....yes it will work fine.
this also goes for people wanting to run a 58mm plate behind a stock or 52mm TB, as long as the intake is machined to 58mm.
You can go larger behind the TB but not smaller
