Nitrous Outlet
Old Mar 19, 2007 | 05:40 PM
funina91ss's Avatar
Nitrous Outlet
Just wanted to let eveyone know how great they are to deal with. They will do everything they can to get you your parts when you need them even take them to ups when on there way home. I was really blown away by that.
Thanks Guy's You have a customer for life
Old Mar 20, 2007 | 08:30 AM
Nitro Dave's Avatar
Ohhh.. Now I know why Chris had to run to UPS after work. UPS had already came so he said he had a package that had to go. Ill have to give Chris a pat on the back today for a good job.
Dave
Old Mar 20, 2007 | 08:59 AM
2000GTP's Avatar
Another satisified customer here as well. Dave went out of his way on the phone to help me get all of my stuff together for the order and figure out a few simple things.
Old Mar 20, 2007 | 09:05 AM
69gto96z's Avatar
I am also a satisfied customer. Have bought a few things from them. But I wish I would have bought my nitrous kit from them, I have been having bad luck with some of my HSW parts.
Old Mar 20, 2007 | 09:43 AM
HarrisSpeedWorks's Avatar
You should try contacting us with your issue then. It's hard to help someone if we aren't contacted. What exactly is going on?
Matt
Originally Posted by 69gto96z
I am also a satisfied customer. Have bought a few things from them. But I wish I would have bought my nitrous kit from them, I have been having bad luck with my HWS parts.
Old Mar 20, 2007 | 09:50 AM
69gto96z's Avatar
I did, I sent my gauge in when it was leaking, you sent me another one very promptly, which I was happy with. I put the new gauge on the bottle, and it leaked in the same spot. I just bought a NX gauge down at the store and it is sealing fine. Also, when I get the bottle filled, it has a small leak where the valve goes down into the bottle. Sometimes my purge works and other times it doesnt, I am figuring that my problem there is a loose connection somewhere, so im not worried about it. Other than that, I have been happy with the kit. I have had other friends run the HSW kits with no probs, maybe I just got a couple of faulty parts?
Old Mar 20, 2007 | 12:53 PM
It's possible, but would be extremely rare to have two defective gauges in a row. Reading through some of your other posts it seems like there a quite a few issues at hand, from exhaust leaks all the way to a possible leaky bottle. Please PM me your name so I can pull up your contact info.
Thanks,
Matt
I did, I sent my gauge in when it was leaking, you sent me another one very promptly, which I was happy with. I put the new gauge on the bottle, and it leaked in the same spot. I just bought a NX gauge down at the store and it is sealing fine. Also, when I get the bottle filled, it has a small leak when the valve goes down into the bottle. Sometimes my purge works and other times it doesnt, I am figuring that my problem there is a loose connection somewhere, so im not worried about it. Other than that, I have been happy with the kit. I have had other friends run the HSW kits with no probs, maybe I just got a couple of faulty parts?
Old Mar 20, 2007 | 01:04 PM
69gto96z's Avatar
Yeah, there is a small leak at the bottle, but when the bottle warms back up after being filled it goes away. As for the gauge, I dont know why 2 of em didnt seal. They were leaking out of the back of the gauge, not where the gauge goes into the bottle. I just put a NX gauge on it and decided to forget about it. Also, my pressure switch for my bottle heater would never make a connection to turn the heater on, even with the bottle at 600 psi. I just connected the 2 wires that go to the pressure switch and it worked just fine. Other than these few small parts, I have been a very satisfied customer. I am just pissed at the car because it is not taking a liking to the nitrous.
Old Mar 20, 2007 | 01:20 PM
DirtyDan's Avatar
I agree with the OP, I've had great service from Ray. I've bugged him quite a few times since I placed my order for some help and additional items and he has been very responsive. I really wanted a plate kit and this one seemed to be the best one on the market. I just hope I can get to the monthly account statement before my wife does......
Old Mar 20, 2007 | 01:37 PM
69gto96z's Avatar
Haha thats how I feel when my g/f wants me to take her out and im like, um.... im broke. Shes like what do u mean your broke. Umm... I just bought some expensive part for my car.....
Old Mar 20, 2007 | 01:52 PM
Ah, I remember you now James. It's funny, today at lunch the nozzle you sent in for warranty came up in discussion. If I remember correctly, the note that was included with the nozzle stated something about a shop doing the install of the kit. If that is the case, and they did what they did to that nozzle, I would highly suggest taking the vehicle to another shop to let them go over it, or for you to with a fine tooth comb. It would explain a lot of the problems you are having. Please send the bottle & pressure switch back in and we'll take a look at them, but please understand that if they are in the same kind of condition that the nozzle was in they can't be warranted. Sorry things are not going smoother for you.
Matt
Old Mar 20, 2007 | 01:57 PM
69gto96z's Avatar
Everything else is in perfect shape. I found out the deal with the nozzle. They screwed it into the nut backwards I guess. I borrowed a friends nozzle when I pulled that one out, and it would not go in. So I flipped the nut around and it went in just perfect. And everything else is in perfect shape.
Old Mar 20, 2007 | 08:14 PM
Nitro Dave's Avatar
Thank you guys for all the compliments..
Dave
Old Mar 20, 2007 | 08:31 PM
funina91ss's Avatar
Dave
I didn't even ask for him to do it. He just said he would without even thinking about it. Make sure you tell him I said thank you very much. You should give him a raise too
G-BODYT56
Jan 14, 2022 11:14 PM
RUENUF
Mar 13, 2016 03:37 PM
Quickss96
Jan 29, 2016 05:56 PM
95blkss
Sep 22, 2015 03:18 PM
Steve69SS396
Track Kill Stories
Aug 17, 2015 08:48 PM
