Nitrous NEWB
Old Jun 29, 2005 | 08:32 PM
zachattack45's Avatar
Nitrous NEWB
Hey guys, i just finished up building my moter a few months ago and i think the next thing i do is hook up some nitrous. The problem is i dont know too much about it. For all the parts that i put into it, check the sig. It should be ready for some really high amounts but i was thinking somewhere around a 150 shot. I know this is a pretty broad question, but im just looking for what i will need to hook up a safe system right, and how it works exactly. Also how to use it right! Thanks guys
Old Jun 29, 2005 | 09:01 PM
HarrisSpeedWorks's Avatar
Re: Nitrous NEWB
I took a look at your mods and you'll be fine on a 150 wet shot. If you decide on a dry shot I would get some larger injectors. You have a fuel pump so you're fine in that department. When you decide on a kit I also get a few safety parts, like a window switch (allows the nitrous to be activated only during a predetermined RPM band) and a fuel pressure safety switch (kills the nitrous if your fuel pressure drops below a pre set PSI). It would also be a good idea to pick up a bottle heater, to keep your bottle pressure between 900 - 1050 and a purge. If you have any other questions, or would like to go over your set up in more detail feel free to send a PM or give us a call.
Thanks,
Matt
RUENUF
Mar 13, 2016 03:37 PM
Quickss96
Jan 29, 2016 05:56 PM
95blkss
Sep 22, 2015 03:18 PM
nd4spd200
Aug 21, 2015 09:30 AM
Steve69SS396
Track Kill Stories
Aug 17, 2015 08:48 PM
