nitrous ignition ???
Old Feb 15, 2005 | 01:00 PM
4SFEDZ's Avatar
Lightbulb nitrous ignition ???
do i have to upgrade my ignition, im going to go with a 100-150 wet shot. im going to get it dyno tuned. ive already got a walbro 255 intake and was wondering why or if i had to upgrade my ignition. if so what shoult i go with??
thanks terry,
Old Feb 15, 2005 | 07:48 PM
MarkyMark's Avatar
Re: nitrous ignition ???
no you dont have to upgrade the ignition........just get tr6 spark plugs and make sure your opti, and spark plug wires are in a good condition. You will also want a window switch which is sorta ignition related I guess.
Old Feb 15, 2005 | 08:46 PM
R3Dz's Avatar
lol hi im a newb towards N2O can you please explain this window switch for me? is htis a safety switch or something???
Old Feb 15, 2005 | 09:20 PM
MEAN_SBC's Avatar
You're right by calling it a "safety switch." The window switch will activate the nitrous at a preset rpm, and then turn it off, and another pre-set higher rpm. By using it the nitrous system will only function within that certain "window" of the rpm range..... For example, you can set it to turn the nitrous on at 3000, and when the rpm's hit 6000, have it turn it off. This is an excellent safegaurd, and prevents the nitrous system from being activated at too low an rpm, and prevents it from being active if you over-rev the engine.
Old Feb 15, 2005 | 10:02 PM
94Zpower's Avatar
MeanSBC is right a window switch is a must its oo cheap and can save you from a big time blow up, but if you want to get something good get the Mallory 685 box it has a window switch ,timing retard, 2 stage rev limiter and boosts your spark all for $220!
its the best reliable bang for the buck by far,
it's small and instead of having a msd window switch box , timing retard box and the a ing box you have it all in one.
Old Feb 17, 2005 | 07:17 AM
andy katzelis's Avatar
You don't need an ignition upgrade, stock opti on almost 200 shot here. There are some benefits you may wish to consider on the previously mentioned control box.
You should consider one or more of the following: race gas, retarding the timing, and colder plugs on the larger shot size, depending on your intentions with the car on spray.
93 RedBird
Nov 15, 2015 08:24 AM
IndyZman
Oct 22, 2015 02:17 PM
PopoFormula
Oct 12, 2015 04:19 PM
95blkss
Sep 22, 2015 03:18 PM
tommalcolm
Sep 11, 2015 03:39 PM
