Nitrous HP Camshaft
Old Nov 19, 2003 | 12:16 AM
MEAN_SBC's Avatar
Question Nitrous HP Camshaft
Has anyone ever tried the Nitrous HP cams from Comp??? I'm planning on using this cam (NX284H-13) on my 383 stroker with a NX dual stage.. I'm staying hydraulic simply because I cannot afford the roller setup at this time.. The engine is a 10:1 383 forged pistons, rods, crank.... Any input would be appreciated!!!
Old Nov 19, 2003 | 07:30 PM
AutoRoc's Avatar
I have the 274 grind Nitrous HP cam ready to be broken in this week if I can figure out some problems I'm seeing with Rocker Arm to valvespring retainer clearance problems... It should scream pretty good tho!
Old Nov 19, 2003 | 09:26 PM
12Second3rdgen's Avatar
Re: Nitrous HP Camshaft
Never used that cam personally. I have been doing a lot of research on nitrous and it seems that a nitrous cammed motor will put out about 20 more horsepower than a motor with a camshaft optimized for n/a performance, however the nitrous motor will be down 40 horsepower n/a.
Old Nov 19, 2003 | 10:56 PM
DarthIROC's Avatar
From: Teeter-tottering between Brilliance and Insanity
Re: Re: Nitrous HP Camshaft
Plus dont N/A cams bleed off cyinder pressure better? So if you think you are pushing the limits of your block/rotating assembly it may be better to stick with the N/A cam.
Old Nov 19, 2003 | 11:54 PM
Re: Re: Re: Nitrous HP Camshaft
Depending on the N/A camshaft yes. A tighter lobe separation will allow more nitrous to go out the exhaust and in turn lower cylinder pressure.
Old Nov 20, 2003 | 06:11 PM
SVT Killer LV's Avatar
My car did that with some harlan sharpe rockers... threw those in the trash, bought some Comp Pro Mags... best thing I have ever done...
G-BODYT56
Jan 14, 2022 11:14 PM
95chwagon
Oct 16, 2015 12:24 PM
football4life
Oct 4, 2015 07:48 AM
95blkss
Sep 22, 2015 03:18 PM
Daluchman1974
Sep 11, 2015 06:12 AM
