Nitrous Help!!
Nitrous Help!!
I am setting up my fuel system on my car and hoping that some of you can help me. The car is not a camaro, its my Mustang. I have the NOS Cheater Kit for it(carb'd). I would like to do the 150 shot. I have a dedicated fuel system that consists of a Holley Red Fuel pump the free flows 7psi, 1 gallon fuel cell, 6AN line to the Fuel solenoid. I can't seem to get any help from any of the locals for spark plugs. The plugs that came in the car were some Bosch platinums, i cross referenced them to a regular Autolite 45 plug. So my first question is, what would i need? 1-2 steps colder?...and what plug number would that be? Next question is, Would it be safe to spray the 150 shot without pulling any timing out since I would be running race gas in the dedicated fuel system?
All help would be greatly appreciated.
Re: Nitrous Help!!
NGK TR6 ( I step colder) would be fine on a 150 shot. You'll probably be fine with the timing at that power level with race gas. I would start with 4-6 degrees pulled and slowly work my way up.
Re: Nitrous Help!!
Re: Nitrous Help!!
Originally Posted by 89385formula
TR6 will not work with my car. I have old DOOE 351 heads, so its a larger plug. I need to know what plug would be 1 step colder then the autolite 45.
http://www.ngksparkplugs.com/apps/ca...uv/results.asp
Maybe you could just send them an email and see what NGK has to say?
Re: Nitrous Help!!
Re: Nitrous Help!!
Originally Posted by HarrisSpeedWorks
I wish it was!! All those listed are 14mm plugs, I believe mine is an 18mm...and it takes a 13/16" socket.
Thanks though.
RUENUF
Mar 13, 2016 03:37 PM
