nitrous
Old Jun 7, 2007 | 09:19 PM
silver0306's Avatar
nitrous
New to the N2O world
i have 120000 on the car. to high for N2O If not what kit and accessories and safety equipment
thanks
Old Jun 7, 2007 | 09:43 PM
Boosted_Z28's Avatar
There are several people with 100,000+ mile cars that are spraying a modest shot of nitrous (modest meaning probably not much more than a 100-125 hp), but that doesn't mean that every high mileage car will withstand the added stress that nitrous will deliver. IF the car is in reasonably good condition, has been reasonably maintained and there are no signs of engine problems, IE. low oil pressure, excessive blow-by, burns/consumes oil, etc. then you can feel reasonably assured that spraying your car with up to a 100 shot would not cause any problems. If you do decide to spray the car, it should be a chance you're willing to take. Most importantly, you need to be sure you utilize all the necessary "safety" devices to help ensure your motor lasts.
If you are interested in purchasing a kit, I would highly recommend you contact Nitro Dave's Nitrous Outlet /www.nitrousoutlet.com as they offer everything you would need to safely run nitrous on your car, their prices at grat and their customer service is top notch! Not to mention they are a supporting vendor on this site. Check out the "stickys" at the top of this section as there is some good information in them.
Old Jun 7, 2007 | 10:15 PM
Ray@NitroDaves's Avatar
one thing I would reccomend before spraying is do a compression and leak down test on the car...this will give you an idea on how well the rings and vals are seated. If those 2 test come back with postive results you should be fine to run nitrous.
RUENUF
Mar 13, 2016 03:37 PM
Quickss96
Jan 29, 2016 05:56 PM
95blkss
Sep 22, 2015 03:18 PM
nd4spd200
Aug 21, 2015 09:30 AM
Steve69SS396
Track Kill Stories
Aug 17, 2015 08:48 PM
