nitrous
Old May 2, 2004 | 02:09 PM
BLACKBIRD8200's Avatar
nitrous
Does anyone know how the dry nitrous kits works on a 93 LT1 with no mass airflow sensor? How does it make up for the extra fuel needed?
Old May 2, 2004 | 07:40 PM
QCKZ28's Avatar
the kit should have a inline fuel pump with it. a vacuum regulator on the fuel side engages when the nitrous is on and turns the fuel pressure up to 80-90psi to give you the added fuel you need.
keep in mind the high pressure will lock up stock injectors, you need SVO's to be safe.
jesse
Old May 2, 2004 | 07:49 PM
'93 formy ...'s Avatar
jesse
I disagree a bit. I've been using an NOS dry system on the stock 22lb injectors for a good 5 years now with absolutely no problems. 3 of those years were with the 150 horse jets and the past two have been with 175. No plroblems yet. If anything, the car used to run waaaay rich till I got the pcm programmed.
However,my car does only have 46k on the odemeter so maybe I haven't had any problems cause the injectors are pretty much still new.
If you have a high milage car, your probably better off getting a new set of injectors. On the other hand, if you have low milage like I do, your injectors should be fine.
Old May 2, 2004 | 08:42 PM
QCKZ28's Avatar
$200 for a set of better injectors is cheap insurance. all it takes is one time for your stock injectors to lock closed, and BOOM!
i personally would not go with a dry kit and stock injectors.....
RUENUF
Mar 13, 2016 03:37 PM
Quickss96
Jan 29, 2016 05:56 PM
95blkss
Sep 22, 2015 03:18 PM
nd4spd200
Aug 21, 2015 09:30 AM
Steve69SS396
Track Kill Stories
Aug 17, 2015 08:48 PM
