NGK TR6 gap?
NGK TR6 gap?
Is .035-.038 the correct gap for a stock head LT1 with spray? I have mine gapped at .038 and put them in the car and it now has a slight low rpm stumble between 1200-1700rpm.
Your gap is correct. The 6's are a cold plug, that makes low rpm operation less smooth. So really you just learn to live with it or go with 55's and pull some timing or run it a little richer on the spray. I have 6's at .035 and longevity has been outstanding.
