New to Nitrous got some ?s so I dont kill my LT1
Old Feb 13, 2003 | 10:04 PM
Blue89Bird's Avatar
OK, first off, I'm going to be running a Wet 100HP shot.
What do I need to do to run this on a 100% stock car.
It's a 6 speed if it matters.
It is a:
NX N2O Kit + FPSS + Blowdown kit
This is a standard NX wet kit for GM fuel-injected vehicles with 10# bottle. Gets the fuel from the schrader valve/test port on the fuel rail.
It has everything that came in the kit 2 yrs. ago: WOT switch, master switch, mounting brackets, etc., except for a few HP pills. Only has 100 and 150HP pills. But other sets can be bought cheaply if you wish. It has some wear on the outside being this old, but everything works fine.
It also comes with a FPSS, safety blowdown fitting and tube, special bottle mounting bracket for the spare tire area of 4th gens.
What doesn't come with this that I will need, I need to make this AS SAFE AS POSSIBLE. What is a window switch and do I need it?
How hard of an installation is this? Do you have to run lines outside of the car or do they run inside or what?
Sorry for the stupid questions, but I want to research this before I kill myself and my car.
Old Feb 13, 2003 | 10:20 PM
jcolez28's Avatar
You will be very happy with this kit. The window switch will turn the juice on and off for you. THis is important for you becouse if you juice below 3000 RPMs, you greatly increase your risk of damaged piston or blown rings. And the top cut off will save you when you miss a gear or over rev. Get the even pills and go 3000 to 5400 for stock. The dig 6 will retard your timing for you. The rev limiter is better becouse it still allows burning in the piston after the cut off. I recomend 3 degrees for stock 100 shot to be safe. It is a must and looks cool too. The bottle warmer is a must also. This is a sure way for an LT1 to eat 95% of the competition on the street!
Old Feb 13, 2003 | 10:27 PM
Blue89Bird's Avatar
it doesnt come with a dig 6. do i need one? do i need to change my plugs?
Old Feb 14, 2003 | 12:10 AM
jcolez28's Avatar
The dig 6 is more of a safety device. I guess you wouldnt have to have it, but I wouldnt run N2O w/o it, yes you need NGK plugs. They are only about $1.50 each in Summit and I would trust my motor to no other. Also do you have a gauge? It is very important to keep your pressure at the desired amount. Spend some time investigating N2O on the web. Out of all my mods, nothing came close to the power of N2O. But saftey of my mill was very important so I went the extra expense of the RPM switch, Dig 6 , plugs, wires, coil, warmer and guage.
Old Feb 14, 2003 | 06:17 AM
RacinLT1's Avatar
Yes you do need to change the plugs. Platinum plugs retain heat and can lead to detonation or pre ignition.
NGK or Autolite 103/104 plugs are fine,dont have to be NGK.
Old Feb 14, 2003 | 11:16 AM
old93z's Avatar
autolite 104's didn't run so well in my car, ngk tr55's solved the problem some have run autolites w/o trouble though.
Old Feb 14, 2003 | 08:57 PM
stik6shift93's Avatar
You'll want a coil and iginition. The digi 6 is a good choice but is a bit expensive. If you're only going to spary a 100 bigger an NO bigger. You can get a regular iginition that doesn't have adjustable retard and save a 100 bucks. If you're not sure if you want to spray bigger than 100 then get the digi 6 cause you will want to spray more(trust me) and you'll need to retard the timing. Also it wouldn't be a bad idea to get a better fuel pump, if your only gonna spray a 100 then you can get away with the stock if your going bigger get a better one. Good luck
Old Feb 14, 2003 | 11:47 PM
sprayed97Z's Avatar
ive had the autolite 103's for over a year gapped at .45.still on the same set.never a problem.about 30 bottles later they still look new.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
MadMav
May 25, 2015 09:35 PM
bandit383lt4
Dec 21, 2014 09:12 PM
Lt1son
N2O Tech
Nov 25, 2014 01:52 PM
