need wiring help asap
Old Jul 10, 2003 | 09:33 PM
sniffin94's Avatar
We just finished peicing together a nitrous kit for my friend and all we have left is the wiring anyone got a quick diagram or explanation for me. thanks in advance
Old Jul 10, 2003 | 11:47 PM
LT1Z28's Avatar
which kit
Old Jul 11, 2003 | 02:47 AM
JordonMusser's Avatar
West South Central Moderator / Special Guest
not sure what you mean.
The solenoids need power. give them power.. preferably only when a window switch, arming switch and WOT are all activated.
nothing really to it. oh, and use a relay. solenoids can move some current!
Old Jul 11, 2003 | 12:49 PM
slow's Avatar
really dirty example, but gives the idea.
your need a relay, this will have 2 small wires( pin 85 and 86) , and 2 large wires (pin 87 and pin 30)
You need to have pin 30 going to battery +12 volts
Pin 87 going to the selonoids.
Pin 85 to your ARM switch, and WOT switch.
Then pin 86 going to ground, if you are running a window switch, connect 86 to the window switch instead.
connect the other end of the selonoids to ground, and you are done.
note: you can switch pins 85 and 86, with no problems.
Ryan.
Old Jul 11, 2003 | 02:06 PM
kirschman's Avatar
try this..........http://gallery8926.fotopic.net/photo.php?o=13&id=550122 this is meant to be used with a w/s msd 6AL and a FPSS
Potent77
Mar 16, 2022 12:13 AM
Heathen1
Jan 2, 2016 04:27 PM
PublicEnemy1
Apr 7, 2015 12:21 PM
Potent77
Apr 1, 2015 12:45 AM
jj_burchiel
Classic Engine Tech
Mar 13, 2015 11:20 PM
