Need some N2o help
Old Dec 12, 2003 | 12:16 PM
Rocks94z28's Avatar
Need some N2o help
i am planning on hooking up a wet kit this winter i just need to know what i need still,
i have msd 6al w/ rev control already and i will install ngktr6 plugs soon, i have a 94 z with a stock fuel pump, new filter,
do i need a new intank pump or inline pump or nothing at all?
do i need a fuel pressure regulator?
I want to spray a 100 shot and maybe eventuall spray 150 shot, don't worry guys my ride's paid for,
i also plan on putting on a purge kit and of course a fpss,
any help or advice is appreciated,
jesse
Old Dec 12, 2003 | 12:27 PM
RacinLT1's Avatar
window switch to save the trans. also might wanna do the fuel pump before you go to 150,cheap insurance. fpr isnt needed.
Old Dec 12, 2003 | 12:33 PM
TRIPLE G's Avatar
I would agree. Window swich is great to have. My tranny is still going strong(knocks on wood) I run a 150 shot (NX) with the stock pump,injectors and fuel pressure reg. But i will be dropping a 255 in this month. Just check your A/F. Makes sure the car isnt running lean of the juice then check it on the juice. As long as it isnt going lean you are ok but i would look to swap out the stock pump when you can.
Old Dec 12, 2003 | 08:17 PM
Z28ROC's Avatar
A bottle heater is also a good idea. A must IMO.
Old Dec 16, 2003 | 07:46 PM
Rocks94z28's Avatar
i have a built tranny so i am not too worried about that and what exactly does a window switch do?
i will not be spraying too often either and i have newer head gaskets'
also should i spray off of the line if i have et streets?
Old Dec 16, 2003 | 07:49 PM
RacinLT1's Avatar
window switch shuts off nitrous during shifts.
spray off the line if you can,best ET gains will come that way,as will a grenaded 10 bolt rear.
Loonies
N2O Tech
14
Sep 5, 2022 04:53 AM
cristian1311
N2O Tech
Jun 5, 2015 05:08 PM
Jlo
Feb 3, 2015 09:41 PM
tbyrne
Aug 16, 2002 01:12 PM
kirschman
N2O Tech
Jul 14, 2002 07:29 PM
