Need Advice!
Old Jun 16, 2005 | 09:08 AM
sunsetorangess's Avatar
Need Advice!
I'm about to get the NOS 5177 kit and runnin about 100-125 shot with the mods in my sig. Do i need to update anything (fuel pump, etc) or can the stock fuel pump, etc. handle 100-125 shot.
Old Jun 16, 2005 | 09:37 AM
HarrisSpeedWorks's Avatar
Re: Need Advice!
I would add a fuel pump, and depending on how much you spray, larger fuel injectors (and a new tune for them). If you're thinking of a 125 shot or higher you might want to consider a wet kit. We're have a 15% off dry kits and 10% off wet kits now. If you have any other questions let us know.
Old Jun 16, 2005 | 09:55 AM
Re: Need Advice!
Honestly, the highest i'll probably go is 100 shot. How do you add a fuel pump? Also do i really need new injectors for 100 shot?
Also how much $ would a fuel pump cost and how hard is it to install? Sorry for the ignorance, i'm learnin!!
Old Jun 16, 2005 | 10:23 AM
Re: Need Advice!
Do you know what your RWHP is? You're right on the borderline for the larger injectors.
I would look at a Racetronix fuel system. They are pretty easy to install, and you have two ways of doing it. One is to drop the tank (harder way). The other is to cut a hole through the body above the gas tank. Then you can just pull the pump up. It's not as bad as it sounds, a lot of guys don't like to hear about cutting up there cars. There are a few good resources on the internet for doing it that way.
Old Jun 16, 2005 | 10:56 AM
Re: Need Advice!
So if i went with a wet kit would i have to change all of that?? I really would like to avoid having to either pull my gas tank off or cut a hole in my car. Thanks for the replys.
I'm around 400rwhp right now.
Old Jun 16, 2005 | 12:52 PM
Re: Need Advice!
You would not need the injectors (or tune) with the wet kit. People have been successful with your mods spraying a 100 shot, just as other people have not. I would do a fuel pump if it was my car. Another idea might be to install a wet kit and spray it on a dyno for the first time. Watch your A/F with the wideband while watching the fuel pressure. That should give you a pretty good idea. A fuel pressure saftey switch would help too.
Jeff1904
Jun 5, 2016 05:00 PM
David Dempsey
Mar 12, 2016 12:42 AM
WobblySausage
Oct 7, 2015 02:44 PM
WobblySausage
Oct 7, 2015 10:09 AM
68camaroboltz
Oct 5, 2015 01:46 PM
