Need a 200-250 HP adjustable wet kit
I have been looking around at different systems and I am not sure what I want to get.
It has to be a wet kit and it has to support 200 and 250 HP shots.
I have looked at direct port kits from NX for $1300 but Im not sure I want to take off my manifold. I also saw a 100-300 HP adjustable kit that NX makes but it uses a pair of nozzles instead of a throttle plate. It must be a throttle plate or a direct port setup.
What kit should I get ?
And are they rated at the wheels or at the flywheel ?
Thanks for any help
-Taz
Thanks for any help
-Taz
well i want a throttle plate because I do not want to have to put the nozzles into theintake elbow. I would rather have them right at the throttle body. SO its a WANT iguess, but I wont do it any other way then direct port or throttle plate.
Also It cant be a 2 stage, the MSD digital 6 only retards timing for one step.
Originally posted by slp223
you can tap the intake manifold with a single nozzel right behind the throttle body.
Has anyone done this? Sounds interesting. Couldnt he purchase the NX kit then find a plate that fits our cars?
Does anyone even make a plate kit for the LT1?
tnt kits are somewhatr a pain starting out installing them as the lines had hood clearence issues, mines the f2 kit, they just changed the f2 to 6an main line with 4an from the selanoids to plate, so im sure the clearence is still going to be a huge problem as my kit rubbed the hood with the lines.
ezcheeze15
Aug 26, 2002 01:28 PM
ezcheeze15
Aug 8, 2002 12:27 AM
