N2O setting off SES light????
Old Nov 7, 2004 | 11:15 AM
Evildime's Avatar
OK.....This is in my '98 S-10 witha '95 LT1. Never had any troubles with setting off any SES codes before this. Truck has run perfect for almost two seasons and still runs good as of now. I recently installed a NOS EFI universal wet kit on my truck and have been having problems setting off the SES light when I use it...... I finnaly got off my butt and decided to scan it while this happens and this is what I got...
Code 16 (Lo res failure)
Code 47 (Knock sensor module circuit)
Code 48 (MAF system failure)
Code 36 (Hi res failure)
Code 18 (Injector circuit)
code 51 (Prom/Flash error)
So what gives??? Can anybody tell me what is happening to my truck?? When I get this code if I turn the nitrous off in time it goes away instantly.....but If I don't catch it in time it stays on and sends the PCM into limp home mode......I have to shut my truck off....restart it and it's gone.
I have no idea why it would set off all of these codes when I spray?? Any help would be greatly appreciated.
Thanks.
Old Nov 7, 2004 | 01:55 PM
mrr23's Avatar
Re: N2O setting off SES light????
are you shooting through the MAF? being a wet kit, do you have the pills mixed up resulting in too much n2o vs fuel?
Old Nov 7, 2004 | 05:28 PM
Evildime's Avatar
hehe....No. I'm not shooting throught my MAF......and my jetting is good.
Nitrous Jet = 46
Fuel Jet = 32
This system works fine if I only turn it on in like 3rd gear....I have used it many of times in 3rd....but whats the use?? I would like to use it for the entire pass.
Old Nov 7, 2004 | 05:36 PM
mrr23's Avatar
where are you pulling power for the n2o from? might be pulling from the same circuit the PCM is getting power from. doesn't make sense. but, hey it's an option.
Old Nov 7, 2004 | 08:11 PM
Evildime's Avatar
Hmmmmm. I'll have to check......can't exactly remember. I'll look.
Old Nov 7, 2004 | 08:56 PM
GJE94Z28's Avatar
Talking Re: N2O setting off SES light????
I had this very same problem on my LT1 when spraying. Had I believe a code 47, knock sensor. Sure enough, I replaced the knock sensor and all was well in the universe. The old sensor must of got rattled by the spray one day and took a crap. Actually, now that I think about it, It was some silly *** code about the optics. Anyways, just change the knock sensor on the block with a new one.
Old Nov 8, 2004 | 01:21 PM
Evildime's Avatar
That might be a good idea too.......I'll give it a try.
Thanks for the help you guys......this is why I come here.....with all the people on here....somebody has to of had a similar experience and a solution to it.
Thanks.
Jlo
Feb 3, 2015 09:41 PM
Gtpguy
Jan 26, 2015 04:50 PM
sleeperZ96BT
Jun 5, 2005 09:33 PM
Rich_z28
Sep 13, 2002 03:35 PM
Z28Wilson
Aug 1, 2002 04:27 PM
