N2O on a 94'
what they all said,and yes i do recommend pulling timing on a 150 shot if you use pump gas.
if you run good fuel,have a good fuel system,and a strong ignition system,you can run 150 without pulling timing. pump gas and not pulling timing is a recipe for disastor.
i ran a 175 shot on a stock longblock for a full season with no problems,pulled 2-4 degree's depending on weather with good fuel.
