n2o
Old Dec 31, 2007 | 06:40 PM
evanbrendel's Avatar
n2o
i have stock 98 camaro with tires a suspension work and a msd timing twister i have a dual nozzle power ring and i was running a zex box that had the solanoids in it but i have a zex tps controler now and bigger solanoids im runnnig a 150 shot with apropriat timing taken out and apropriate plugs do any of you think this is to much? i ran 12.03 best pass at the track and im going to upgrade gears headers tune and et streets soon.
Old Dec 31, 2007 | 11:50 PM
Chopstix's Avatar
As long as you have enough fuel supply you should be fine at the 150hp level.
If you could add a signature with the major mods to your car it would help with knowing what we are working with.
I see you have the timing twister but you don't mention a custom tune or programmer. On the stock tune you might not need to pull any timing, but at most 1-2*.
Please let me know if you have any questions.
Ray
Old Jan 2, 2008 | 01:44 AM
AF96Z28's Avatar
A 150 shot kind of ries the line of needing a 255 pump. Make sure that FPSS is wrking.
Loonies
N2O Tech
14
Sep 5, 2022 04:53 AM
cristian1311
N2O Tech
Jun 5, 2015 05:08 PM
Jlo
Feb 3, 2015 09:41 PM
tbyrne
Aug 16, 2002 01:12 PM
kirschman
N2O Tech
Jul 14, 2002 07:29 PM
