msd window switch all messed up?
i have a 2001 camaro ss and i put my nitrous stuff from my 94 Z28
and i used the msd window switch and everything, but now when i try to spray i will come on when its supposed to but then it will shut right off. so im wondering if it aint my window switch that is all messed up or what but any ideas will be appreciated.
Thanks Jason
Thanks Jason
from what i understand you have to cut both the blue and the red wires. a buudy of mine has a 02 ws6 with both the red and blue wires cut and he runs mid 11's all day long so i think its my window switch all messed up any other ideas would be appreciated
Thanks Jason
Thanks Jason
Is the fuse blowing once the window switch is activated? Or is it just shutting off? Mine was doing the same thing, but it would blow my fuse everytime. It turned out I had a bad window switch.
No, not necessarily. If it is activating for a second, then that means the switch turns on but thinks it has to turn off right after. What pills do you have in it right now? Maybe its a bad pill? Try a different "Off RPM" pill
1mostlystockz28,
What MSD part number are you using?
If you want a window switch guaranteed to work with your LS1 in 4-cylinder mode, feel free to write me at mike@bmnracetech.com
Speeds8erM-1
Aug 13, 2002 10:24 PM
Speeds8erM-1
Jul 28, 2002 06:18 PM
Speeds8erM-1
Jul 18, 2002 11:36 PM
