MSD 6+ box WTF!!!
MSD 6+ box WTF!!!
I connected my MSD box and go to crank it up and it does not fire. I check all my connections which isnt that many! Im using the GM wiring harness, red 2 red, black 2 black, orange 2 orange, white 2 white. Pulled the connector off the coil and connected the GM harness to it and connected what I pulled off the coil to the harness also.
Im grounded to the body of the car, thick red going to the battery
when I first made connection with the power cable I got a spark and also when I connected ground....NOW I DONT!...whats up?
MSD is closed.
Did I short out the box somehow? how would that be possible?
Im getting so freakin frustrated!!!!!
When I disconnect the MSD and put the connectors back to normal it fires right up.
MSD is closed.
Re: MSD 6+ box WTF!!!
you gotta be kidding me! after doing all that wiring and pulling wires to make it look clean. if thats the case Im pissed! I sure hope MSD replaces the box...
yeah Ive done that before at other stores!...shhhh?! LOL
I had to cut the ends off the wires cause I made them longer...I mounted the box inside the car.
I cant believe this crap!!!!!!
sleeperZ96BT
Sep 9, 2015 08:28 AM
88IROC_Z
Jul 22, 2015 11:38 PM
