mounting nozzles inside intake?
has anyone ever tried mounting two fogger nozzles under the intake manifold so they are threaded through the underside of the manifold and the tips of the nozzles are directly behind the throttle body?? (two nozzles, one behind each throttle body blade) Ive seen direct port mounted under the manifold, so i know the lines themselves can work in there, but would this distrupt airflow too much inside the intake? i dont see why this would not work, it seems like it would act just like a plate system...I want to find a way to install a non-direct port system so that nobody can see any part of it.
Re: mounting nozzles inside intake?
yes you you can do that, but even easier mount the nozzle under the bend in the belllows, where the silencer is. put the solenoids in the silencer.
Originally Posted by will62085
i htought about that, but it would be hard to mount all the lines a wires up there without anyone getting suspicoius of what they are
yeah ive seen that, thats bad a**...but i dont want to do a direct port...i actually bought that kit when i was building my motor and was going to install it, but i was told the 150 shot i wanted was too small for direct port
