micro switch ?
Old Aug 22, 2003 | 05:04 PM
steelheart's Avatar
micro switch ?
instead of putting the micro switch on the throttle body can i wire it to the inside of the car and use it by hand to spray when i want to spray instead of spraying when the throttle wants to??
Old Aug 22, 2003 | 06:37 PM
95 Mystic TA's Avatar
I went to check on my car at the local shop who is doing the install and I was extremely impressed with the way everything is hidden. They took and mounted my microswitch under the shifter plate so that when the button on th shifter is mashed in, it would spray when the system was on and at full throttle. Very good install in my opinion, couldn't even tell the bottle is on. I would take a pic but I won't have the car back until late tommorow.
Old Aug 22, 2003 | 07:07 PM
LPEdave's Avatar
Re: micro switch ?
You certainly can. Of course "the throttle" is your right foot
Dave
Old Aug 23, 2003 | 01:24 AM
BBCAM's Avatar
YOU need to keep in mind that you should ONLY spray at WOT anything other than WOT and you stand the chance of N20 build up in the manifold and that can be costly ....
G-BODYT56
Jan 14, 2022 11:14 PM
IndyZman
Oct 22, 2015 02:17 PM
94Z28LS1toLT1
Sep 22, 2015 05:24 PM
Rod Bender
25
Sep 16, 2015 01:47 PM
jackpawt883
Sep 10, 2015 08:53 PM
