MAF Sensor??
Old May 13, 2005 | 09:49 AM
sunsetorangess's Avatar
Question MAF Sensor??
If i plan on running nitrous is it a bad idea to descreen my maf sensor??
Old May 14, 2005 | 11:55 PM
V8Rumble's Avatar
Re: MAF Sensor??
Well, I don't have a N2O kit, but as I understand it, you're basically mounting the "plate" with the spray nozzles between the throttle body & intake manifold - the MAF is (usually) well upstream of that, & shouldn't care whether you're spraying or not.
(If your MAF does see any N2O, you've got some serious intake flow reversion issues!)
Now if you're somehow spraying your N2O upstream of the MAF, then none of the above applies, & you can just forget that I said anything...
Old May 16, 2005 | 10:27 PM
OBE1 95Z28's Avatar
Re: MAF Sensor??
Never a good idea to remove the MAF screen; it's there to direct the air properly over the sensor.
SergheiS
Jul 5, 2015 03:27 AM
BigED
Jun 23, 2015 07:19 PM
andrewcapps82
May 19, 2015 10:11 PM
pete53
Dec 9, 2014 07:31 AM
