LT4 set-up with N2O quetions??
Anyone run the LT-4 set-up (intake, heads-stage 2, cam, stock bottom end) and run N2O? I'm putting out close to 400 rwhp NA. Looking to add a 100hp NX set-up. Anyone running this combo? What kind of results? Is this combo semi-safe?
Re: LT4 set-up with N2O quetions??
) Most of us don't run the stock bottom ends. You should be OK as long as your combo doesn't lean out. The stock hypereutectic pistons are VERY sensitive to detonation. A high rpm leanout will teach you a lesson in fine art of motor rebuilding. Take your car to a wideband-equipped dyno and make sure your car is properly fueling the fire.
Well I would assume with a 20% valvetrain loss of power I should be close to 475-480 FWHP. Given a 100hp shot of N2O it should be easily over the magical 500 fwhp.
When I do it Ill have a place like SpeedInc install it (already got some prices). I'll have them dyno it as well in-house before they release it to me for thrashing.
The N2O is kind of a long term goal. Gotta get a aftermarket rearend first. Still running the stocker with upgraded gears and Posi unit right now. Who knows how long that will last under 400 RWHP.
sleeperZ96BT
Sep 9, 2015 08:28 AM
