LT1 Plate System Group Purchase!!!
yes it will work with the stock TB....if you have the stock TB and no interest in adding the 58mm at a later date get the 52mm plate. If you are going to add the 58mm later, get the 58mm plate and have the intake bored to 58mm, to remove any lip that might be present behind the TB.
Wow. I must say the LT1 guys really steped to the plate on this. You guys rock!!!!We had more than enough orders to go to production the same week this post started. The order is in and we are waiting on the machine shop at this point. Do to the responce and support we will be bringing this part number back to life.
For the guys that did not pre order. You can still place your order and get the discounted price till the end of next week. MARCH the 23rd is the deadline on this special.
Thank you guys for all the support.
Dave
Dave
Guys,
Our plate conversion does not have a extra bracket for the TV cable on the 93s. The conversion only has a bracket for the throttle cable. I have not tried to see if the tV cable on the 93s are long enough to allow extending forward a 1/2 to 3/4 on a inch. You may have to get creative with your stock bracket. Then again you may be able to just re adjust it. Im not real sure on that one.
Z rated94. We did order more. We have to geta lot more than 10 machined in order to keep it cost affective. I just wanted a commintment of 10 to show us there was a need for this product. Thanks to quite a bit more than 10 people you guys showed us there was a need for this product.
Thanks Guys.
Dave
Thanks Guys.
Dave
Dave, do you have the final dimensions of the plate yet? If you can get me a final thickness of the plate I will talk to one of our vendors at work and see if they can make a cost effective bracket to replace the ones on the 93. I do know that on my 93 there is not enough cable adjustment for the plate thickness. That is why I asked about the new backet when I called.
I dont know much about setting up N2O but I have a singleplane intake with a 90 degree elbow with a monoblade on my solidroller 383.
will this system work for me?
what about shipping to L1S6A2(toronto Canada)
thanks
Dave
thanks
Dave
And Dave, why not have a few extra made up, even if you can't give the same price in the future?
