LT-1 Microswitch
Old Jan 18, 2005 | 08:41 AM
  #16
brubble's Avatar
Re: LT-1 Microswitch
so the lt1 is in your 68? i love the old car with high tech power!! would definitely love to see some pics.
84 monte SS, sorry to to get off topic on your post. the jimmy jams and nitro dave WOT are the easiest and cost about $30 shipped. you also have the option of the tps but that runs about $100. and you can use the universal just get creative like, andy.
Old Jan 24, 2005 | 06:59 AM
  #17
andy katzelis's Avatar
I have pictures of the gas pedal mounted microswitch if some one will post them.
Old Jan 26, 2005 | 10:20 PM
  #18
captaindbol's Avatar
send em to captaindbol@yahoo.com and I'll put up a link for everyone
Old Jan 27, 2005 | 09:55 AM
  #19
mike 1978's Avatar
the lt-1 is in his 94 F Bird.
the 68 has a 468 with 6-71 blower and nitrous.
Old Jan 27, 2005 | 10:03 AM
  #20
Mystery is solved
http://photobucket.com/albums/v238/c...rent=andy1.bmp
http://photobucket.com/albums/v238/c...rent=andy2.bmp
http://photobucket.com/albums/v238/c...rent=andy3.bmp
http://photobucket.com/albums/v238/c...rent=andy4.bmp
http://photobucket.com/albums/v238/c...rent=andy5.bmp
Old Jan 27, 2005 | 10:15 AM
  #21
Thanks a bunch Captaindbol!
It should be noted the first three pics are from the Camaro where the switch is located on an aluminum bracket then wire tied to the steering column.
The last two are in the firebird. There is no bracket. This is a larger version of a limit switch. Pretty sweet, it lines up real well with no bracket and could be easily removed by sniping the ties. The larger switch can be had at any electrical supply.
One could also use a smaller switch on an LT1 car and add an extension spring placed over the limit switch's lever arm to extend its length. This also helps with any missalignment between the target's path of travel and the switch lever's path of travel.
Just a thought.
G-BODYT56
Jan 14, 2022 11:14 PM
IndyZman
Oct 22, 2015 02:17 PM
DarksideII
Parts Wanted
Sep 23, 2015 11:14 PM
CARiD
Exhaust System
Aug 3, 2015 05:10 AM
1995Blackz28
Jul 20, 2015 09:34 AM
