Lowest HP shot on an LT1?
Old Mar 3, 2003 | 02:20 AM
96cam4ro's Avatar
Is it possible to go with a 50 HP shot for an LT1? All the kits I see are made for a minimum of 75 HP shot. I'm leaning towards NX. Thanks.
Old Mar 3, 2003 | 02:41 AM
speedmiser's Avatar
Yep, you just need the right pills in the nozzle or plate. Ask the vendor you want to buy from, if he'll sub the smaller pill set for the larger pill set. If not, you'll need to buy the pills seperately.
Old Mar 3, 2003 | 08:34 AM
stik6shift98's Avatar
yes i think some even go as low as 25 hp
Old Mar 3, 2003 | 12:42 PM
stik6shift00's Avatar
Why do you want a 50 shot....did you do a 4 cylinder engine swap?? hhaa j/k do 75
Old Mar 3, 2003 | 01:39 PM
95greendragon's Avatar
My NX came with 35 shot, pretty useless though. I have been running the 100 shot for months now no problems. Just check the fittings and make sure they don't leak.
Old Mar 3, 2003 | 01:55 PM
civic_hunter's Avatar
wth?! why 50 shot? you got your self a lt-1 use it
Old Mar 3, 2003 | 07:15 PM
stik6shift93's Avatar
You'll be fine spraying a 100 the motor will handle it all day long.
Old Mar 3, 2003 | 08:19 PM
96cam4ro's Avatar
I've got 112K miles and I was just worried about frying the pistons, driveshaft or Tranny. Thanks for the input guys!!
Old Mar 3, 2003 | 08:21 PM
The engine will be fine I might be worried about the tranny tho.
Old Mar 4, 2003 | 01:11 AM
chesee48's Avatar
no way
Old Mar 4, 2003 | 12:52 PM
the 25 shot yeah they do, imports cant handle much more
Old Mar 4, 2003 | 12:54 PM
yup thanks stik00 i wass just gonna post the same thing
Old Mar 6, 2003 | 08:07 AM
Well when you only have 100 hp in the first place.....
Old Mar 6, 2003 | 06:02 PM
Originally posted by aggiez28
on a z28 i mean
of course you would on a little import
brook
i was gonna say on an import...on a z28 u might notice a slight difeerence in power...
Old Mar 6, 2003 | 06:16 PM
I think a strong wind behind you would help more than a 25 shot...haha
