Impala Head Gaskets For N20?
Old Dec 15, 2003 | 11:25 PM
1995ta's Avatar
I am going to replace my stock head gaskets with Impala head gaskets when I install my cam and port my heads. Later this summer I will be spraying a 125 wet shot, and was just wondering if anyone has experience using the Impala gaskets and N20?
Old Dec 16, 2003 | 02:57 PM
Josh-'04 GTO's Avatar
I'm running Impy head gaskets with my stroker and a 200 HP shot of nitrous with no issues. FWIW, head gaskets should have pretty much no bearing on whether or not you run nitrous.
Old Dec 16, 2003 | 05:29 PM
Wild1's Avatar
Head Gaskets will increase both your dynamic and static compression ratio. That will directly affect your cam... vice versa. Mr. Gasket makes copper gaskets at .020 They are re-usable and seal great!
Also, your stock deck height is .025... add .020 for the copper gasket and you'll have a quench of .045. The best target for quench is .035-.045... you'll be at the edge of the sweet spot.
Old Dec 16, 2003 | 10:06 PM
Since when is that a bad thing with nitrous?
Old Dec 17, 2003 | 01:57 PM
roguedriver's Avatar
Mine
My Impy gaskets work fine. 150 dry shot.
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Jazsun
Dec 29, 2014 12:14 PM
thenewkid
Nov 27, 2014 09:41 AM
