Ignition question
Old Jul 16, 2004 | 11:47 AM
94NDTA's Avatar
and other questions
So far, I have the ignition control plug, the power and the ground hooked up. What do I need to do with the magnetic pick-up, weatherpack connector, H/S retard input, RPM switch output, and the staging control input. Please answer if you can.
Old Aug 1, 2004 | 05:18 PM
94NDTA's Avatar
Re: Ignition question
Anyone? I still don't know how to hook it up. Can anyone help me hook this up with my nitrouse?
Old Aug 1, 2004 | 09:44 PM
SDAKOVIC's Avatar
are you using an MSD?
Old Aug 3, 2004 | 05:26 PM
94NDTA's Avatar
I probably should have specified. I am using a Mallory 685. I have no idea how to hook it up with conjunction with my n20 kit.
Old Aug 4, 2004 | 06:02 PM
94NDTA's Avatar
Ok, can someone at least answer me this. Would I call NX, or Mallory for technical support on this?
Old Aug 5, 2004 | 05:17 PM
94NDTA's Avatar
aaaaaanyone?
Old Aug 7, 2004 | 05:23 PM
94NDTA's Avatar
Ok, well, I'll give Mallory a call, but thanks for the help.
Old Aug 11, 2004 | 02:26 PM
94NDTA's Avatar
Allright....well I contacted Mallory, and here is the response I got this.
"The violet wires are for the NOS. Ground one of the wires and the other is a ground to the NOS solinoid to activate it. What I recommend is that you get a horn reley and use the violet wire as the ground to activate it and send the 12 volts power to the solinoid. This is a more positive way to wire it in. "
The only problem is I only see one violet wire on my ignition and I still don't know what to do with the remaining yellow and orange wire. I contacted them again and they said the same response. I am really frustrated. How can I do this if even mallory can't help me out? If you know at all about this PLEASE for the love of god, guide me on how to do this!
Old Aug 11, 2004 | 06:35 PM
kevmor99's Avatar
I could help if I knew what wire did what on the mallory. Do you have a manual or anything? Or do they have the manual on their website?
Old Aug 11, 2004 | 06:40 PM
kevmor99's Avatar
Ok, it looks like this is the manaul:
http://go.mrgasket.com/pdf/685_6851.pdf
Old Aug 11, 2004 | 06:52 PM
kevmor99's Avatar
You set the RPM window switch on the unit, then when it is in that range, the violet wire will be grounded. So you could use a relay:
86 violet wire from mallory
85 b+
30 b+
87 switched b+ that will have power when 86 is grounded to put power to your nos solenoid
I got that from the top of page 12. You got the Hyfire VI ?
Old Aug 11, 2004 | 06:54 PM
94NDTA's Avatar
The yellow is the H/S retard input (+12 volts activates), the violet is the RPM switch output, the orange is the staging control inpu (+ 12 volts to avtivate).
Old Aug 11, 2004 | 06:56 PM
94NDTA's Avatar
Yes, I have the hyfire 685 IV. I am understanding the window switch, what I don't understand is the yellow h/s retard input.
Old Aug 12, 2004 | 05:42 PM
Loadre's Avatar
Buy the wiring harness from Jegs. Problem solved.
Old Aug 12, 2004 | 10:02 PM
94NDTA's Avatar
Wrong yellow wire. I allready have the wiring harness, it doesn't include ALL the wires.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
97Z28Muscle
Feb 6, 2015 10:44 PM
Ari G
Dec 11, 2014 03:21 PM
lbrowne
Nov 13, 2011 04:25 PM
