Ignition with Nitrous
Old Jul 18, 2005 | 02:30 PM
buzz12586's Avatar
I am planning on running the dynotune nitrous kit soon and I was wondering how to tie the MSD Window Switch and Mallory Retard Control together?? Will these work with my stock ignition or will I have to get something like the MSD 6A??
Old Jul 18, 2005 | 06:17 PM
buzz12586's Avatar
Re: Ignition with Nitrous
No one has any experience with this??
Old Jul 18, 2005 | 08:41 PM
pennys58's Avatar
From what I was told, it is pretty difficult to even put a timing control on our cars...unless you splice it into the actual pcm, have a digital box, or program it into the car. I am going through the same troubles right now. I have the 6AL, msd retard and digital window switch...and have been told I'm plain out of luck!! Take the timing out through the pcm and I lost over 20rwhp!! Do a search under my screen name and read away...very dissapointing!
Old Jul 19, 2005 | 09:01 AM
MichiganSkip's Avatar
I think MSD shows a wiring diagram for hooking the retard box into the 6AL on your car. Did you buy the harness to hook the 6AL to the coil?If so MSD shows a hook up for your setup
Old Jul 19, 2005 | 09:58 AM
AF96Z28's Avatar
Personally, I'm not running a timing retard box. I have a 6AL w/ window switch. I used tunercat to pull 2 degrees at everything above 3400 at WOT in a "NO2 only tune"
Old Jul 19, 2005 | 01:47 PM
buzz12586's Avatar
Can I run the window switch without a 6AL ignition?? Losing 10-20whp N/A is pretty crazy. I guess I could simply have 2 seperate tunes and just load a "NO2" and a "N/A" tune.
Old Jul 19, 2005 | 09:34 PM
wicked_95z's Avatar
I have a mallory hyfire vi that has a timing retard when 12vdc is applied to a certain wire on the box. Also has a boost referenced timing retard. Pretty handy box
Old Jul 19, 2005 | 11:35 PM
I believe you can. The function of the window switch is to turn something on or off at a certain rpm. So I'm sure you can trigger it to fire yourr Mallory Retard box. Just remember that the contact inside the window switch won't handle a lot of amperage. It just needs a signal from your tach and when the signal matches the pill you've put in, it will fire the retard box. If you would like I can set you up with the schematics for how to wire you nitrous up.
Shoot me an email at skipwillis@comcast.net and I'll fix you up
Old Jul 20, 2005 | 01:10 AM
buzz12586's Avatar
That makes sense. The window switch I was looking is this one
http://www.dynotunenitrous.com/store...?idproduct=138
So I would just run the output of that to the timing retard box as well as the relay for my nitrous. Correct??
Old Jul 20, 2005 | 08:27 AM
What is Mallory's part number of your mallory retard control?
Old Jul 20, 2005 | 09:36 AM
buzz12586's Avatar
I remember a retard control by Mallory being mentioned in another thread but now I can't find it. I was just asking questions before hand so I know what I need to get once I have enough money.
Old Jul 23, 2005 | 10:29 AM
IEAT50Z's Avatar
The mallory box has Window switch, Timing retard and its a ignition all in one.
Thats why I don't like MSD b/c you have to buy like 5 different little boxes.
Old Jul 23, 2005 | 05:40 PM
pennys58's Avatar
Where's the best place to get the mallory?
Old Jul 24, 2005 | 07:48 AM
wicked_95z's Avatar
I looked around quite a bit and I bought my from Jegs on sale but I think they still have the best price. I think they run about 230 or 240
Old Jul 24, 2005 | 09:25 AM
Joe Brodman's Avatar
GP Moderator
I've got the same box; it's awesome. I had a MSD Digital 6 and a seperate window switch. I was able to sell both of those used for more than what my Mallory cost me.
That fact you can just change any setting you want w/ a push of a button is a big plus. Will also wire in easily using an MSD LT1 harness.
