Ignition with Nitrous
I am planning on running the dynotune nitrous kit soon and I was wondering how to tie the MSD Window Switch and Mallory Retard Control together?? Will these work with my stock ignition or will I have to get something like the MSD 6A??
Re: Ignition with Nitrous
From what I was told, it is pretty difficult to even put a timing control on our cars...unless you splice it into the actual pcm, have a digital box, or program it into the car. I am going through the same troubles right now. I have the 6AL, msd retard and digital window switch...and have been told I'm plain out of luck!! Take the timing out through the pcm and I lost over 20rwhp!! Do a search under my screen name and read away...very dissapointing!
Can I run the window switch without a 6AL ignition?? Losing 10-20whp N/A is pretty crazy. I guess I could simply have 2 seperate tunes and just load a "NO2" and a "N/A" tune.
Shoot me an email at skipwillis@comcast.net and I'll fix you up
That makes sense. The window switch I was looking is this one
http://www.dynotunenitrous.com/store...?idproduct=138
So I would just run the output of that to the timing retard box as well as the relay for my nitrous. Correct??
I remember a retard control by Mallory being mentioned in another thread but now I can't find it. I was just asking questions before hand so I know what I need to get once I have enough money.
Originally Posted by wicked_95z
I have a mallory hyfire vi that has a timing retard when 12vdc is applied to a certain wire on the box. Also has a boost referenced timing retard. Pretty handy box
That fact you can just change any setting you want w/ a push of a button is a big plus. Will also wire in easily using an MSD LT1 harness.
