I need some quick answers if you would not mind!
Old Dec 28, 2006 | 12:05 PM
mmiikkee's Avatar
I just had the NOS 5130 wet kit installed on my 99 camaro ss... The kit is for 4 or 6 cyls but I guess the only difference is it's a single fogger.
Anyways I'm going to be spraying a 75 shot and want to run as SAFE ASAP! Can you tell me if I bought the right things and what else I need to buy.
http://cgi.ebay.com/ebaymotors/ws/eB...1720615&rd=1,1
http://cgi.ebay.com/ebaymotors/ws/eB...7516515&rd=1,1
http://cgi.ebay.com/ebaymotors/ws/eB...0474402&rd=1,1
These are 3 things I have boughten so far... I also plan on buying a purge kit today on ebay but do I need the 4an or 6an? Also is there some kind of other piece needed for the fpss? I have the NGK TR6 plugs also. I'll also be buying a bottle pressure gauge and it should read in between 900-1100 psi?
Last question:
I'll also be getting a full tune before I spray so does he mess with my a/f ratio to make it right?
Thanks guys and if you could answer all this I would very much appreciate it.
Old Dec 28, 2006 | 12:26 PM
Ray@NitroDaves's Avatar
Last question:
The WOT switch will work, but should have been in the kit, did you buy the kit new?
The window switch will need the RPM pills, they are sold in 1000rpm packs, so you will need the 3K, and either the 5K or 6K pack, depending on where you want the shutoff.
THe FPSS will need a 4AN Manifold to connect to the fuel rail.
Not sure on what else you need, as I am not sure what all you have.
Give me a call and I will help go over it with you.
Ray
Old Dec 28, 2006 | 12:47 PM
2000GTP's Avatar
I would probably just get the 4an style purge kit as well to match up with everything else. Yes, a bottle pressure gauge is a good idea to monitor pressure and make sure it stays in the 900-1050 range. You may also consider purchasing a bottle heater to aid in maintaining the target bottle pressure.
Formula Steve
Sep 19, 2023 08:31 AM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
Ks0209
Oct 1, 2015 07:32 AM
NewsBot
Sep 14, 2015 09:20 AM
Daluchman1974
Sep 11, 2015 06:12 AM
