hypertech power programming and n2o
Old Sep 19, 2003 | 03:06 PM
hambone3441's Avatar
Can you use the power programming with n2o or do I need to disable that with the programmer before using the nitrous? Thanks for any input.
Rob
95 Camaro z-28 - K&N CAI, HYPERTECH AIRFOIL, 160 THERMO, UNDERDRIVE PULLEYS, AND POWER PROGRAMMING, EDELBROCK HEADERS, NO CAT, FLOWMASTER EXHAUST, TB BYPASS, RICHMOND 3.73 GEARS(01 WS6 REAR END), KYB AGX ADJ STRUTS/SHOCKS, LAKEWOOD LCAs.
nx kit coming soon!!!!!!!!!
8.4 in 1/8 on mt et streets
Old Sep 19, 2003 | 11:09 PM
Hawk's Avatar
I'd disable it, like it worked when it was enabled anyway, lol.
You want your PCM with STOCK timing tables for juice so u know where your at.................
Old Sep 20, 2003 | 10:39 AM
Fuels94TA's Avatar
I belive the hypertech programmer is design to advance your timing. When on the bottle the timing should be retard. When your timing is advance you will cause damge to the motor.
Vinny
Old Sep 20, 2003 | 12:28 PM
sssalah's Avatar
I've seen the hypertech timing tables through LT1-edit and it had anly a fue cells don't remember 4 or 6 with slightly more timing than stock and they were at the mid rpm and higher loads.
Old Sep 20, 2003 | 03:09 PM
rpm4lalo's Avatar
When I was running a 100 shot with light bolt ons I left the worthless programming in. When I stepped up to the 160 shot, I took it out and went with LT1 Edit.
cristian1311
N2O Tech
Jun 5, 2015 05:08 PM
thenewkid
Nov 27, 2014 09:41 AM
SLIMJIM
Jan 7, 2003 11:06 AM
XtremeLt1
Sep 13, 2002 08:50 PM
94z28jbw
Sep 8, 2002 03:22 PM
