Huge Moving Sale!! 1 week only!!
Old Feb 8, 2009 | 04:16 PM
Nitro Dave's Avatar
Nitrous Outlet is moving. We do not have an exact day of moving yet but it will be in about a week and a half. We are waiting for the building to have all the data and phone system finished.
To make this move alittle easier on the staff and movers we are holding this one week sale. The goal is to sell alot of the bulk inventory. This lowers our moving cost and puts big savings back into your pocket. We will not have another sale like it! For this week (February 9th - 15th) stay focused on this post. I will be adding items as I get word on what to add.
Do not miss out on these killer deals!
How to Order
Most parts listed will have a link back to our website. You can purchase the item on our website. When you go into the check out page there will be a section for posting notes. In this section it is important for you to type (SELL IT) in order to get the special pricing. If the item listed in this post does not have a link to the website you will have to call in your order at 254-420-3630.
Ok on to the deals!!
1. Brand X Purge kit -This purge kit is a smoking deal. Do not let the low cost fool you. This solenoid is designed to open at pressures as high as 1300psi.
ONLY 55.00
http://www.nitrousoutlet.com/catalog...roduct_id=2890
2. Brand X N20 pressure gauge- This gauge is going to have a black face and liquid filled. Keep in mind the picture on the website shows white face. It is a black face instead.
ONLY 16.00
http://www.nitrousoutlet.com/catalog...roduct_id=3201
3. Nitrous Outlet Glow-N-Dark N2O Pressure gauge- This is the only bottle pressure gauge in the world that will glow in the dark. It has a white face and is liquid filled.
ONLY 24.00
http://www.nitrousoutlet.com/catalog...roduct_id=2546
4. Brand X 10lb Bottle's- Brand X bottle's are black with a high flow valve.
ONLY 120.00
http://www.nitrousoutlet.com/catalog...roduct_id=2958
5. Nitrous Outlet 15lb Bottle's- Nitrous Outlet bottles are black with a high flow valve and dual accessory ports.
ONLY 159.00
http://www.nitrousoutlet.com/catalog...roduct_id=2875
6. Nitrous Outlet Fuel flow tool- This certified gauge is a must to properly dial in your flowing fuel pressure for your nitrous system.
ONLY 179.00
http://www.nitrousoutlet.com/catalog...roduct_id=3531
7. NHRA Blow off Valve- This is a must have to pass tech inspection at the track.
ONLY 16.00
http://www.nitrousoutlet.com/catalog...roduct_id=2550
8. Blow Down Tube- Another must to pass tech inspection. The picture on the site shows a black nut. These are made with a blue nut.
ONLY 10.00
http://www.nitrousoutlet.com/catalog...roduct_id=2516
9. Nitrous Outlet T-shirts- Nitrous Outlet T-shirts are made from 100 percent pure cotton. This sale is only good for in stock shirts. If your color is not instock we will contact you to let you know.
ONLY 10.00
http://www.nitrousoutlet.com/catalog...del=60&dept=11
10. Nitrous Outlet Automatic bottle heater- Nitrous Outlet bottle heaters are designed for the best look, fit, and responce time. The pressure switch is fully adjustable with the closest tolerences on the market.
ONLY 139.00
http://www.nitrousoutlet.com/catalog...roduct_id=2775
11. Nitrous Outlet Dual Stage 78mm plate conversion- Nitrous Outlet is the only company in the world that offers this plate in a dual stage configuration. This will flow 400 hp per stage and offers the best fitment and attomization on the market.
ONLY 265.00
http://www.nitrousoutlet.com/catalog...product_id=997
12. Nitrous Outlet Dual Stage 90mm Plate conversion-Nitrous Outlet is the only company in the world that offers this plate in a dual stage configuration. This will flow 400 hp per stage and offers the best fitment and attomization on the market.
ONLY 265.00
http://www.nitrousoutlet.com/catalog...product_id=994
13. Brand X Nitrous Solenoid- This budget friendly small base solenoid is designed to support up to 200 hp and provide reliable results.
ONLY 50.00
http://www.nitrousoutlet.com/catalog...roduct_id=3503
14. Brand X Fuel Solenoid- This budget friendly small base solenoid is designed to support up to 200 hp and provide reliable results.
ONLY 50.00
http://www.nitrousoutlet.com/catalog...roduct_id=3504
15. 860 HEX to wing adapters- Tired of having to find a wrench to remove your nitrous bottle. We completely understand and that is why we designed the HEX to Wing adapter. Available for both 4 an and 6an main feed lines as well as -8 for the blow down tube.
ONLY 5.00
4an- http://www.nitrousoutlet.com/catalog...product_id=696
6an- http://www.nitrousoutlet.com/catalog...product_id=697
8an- http://www.nitrousoutlet.com/catalog...product_id=698
16. Nitrous Outlet Brand Jets- Nitrous OUtlet has a full line of brass jets. These jets will work in Nitrous Outlet, NX, and Zex systems.
ONLY 3.00 each.
http://www.nitrousoutlet.com/catalog...del=88&dept=11
17. Nitrous Outlet Digital Window Switch- The Nitrous Outlet window switch is the most durable window switch on the market. This unit is designed to take abuse. With its completely sealed and heavy duty construction you can place it in or our of the cabin. This window switch will control 2 stages, has a built in TPS activation option and the gear lock out feature helps aid in traction controll.
ONLY 110.00
http://www.nitrousoutlet.com/catalog...product_id=964
18. Nitrous Outlet Universal Switch panel- This switch panel works on many different applications. I have used it on a C-5 vette, viper and it fits perfectly in the cubby hole in front of the shifter on the F-body.
ONLY 49.99
http://www.nitrousoutlet.com/catalog...roduct_id=2882
19. C5 Bottle Mounts- These mounts epoxies to the floor in the rear of your C5 corvette. It provides a solid mounting surface for bolting your bottle brackets to. Designed for dual bottles
ONLY 99.00
http://www.nitrousoutlet.com/catalog...roduct_id=3460
20. GTO Bottle Mount- This bottle mount bolts to the framing surrounding the fuel tank in the GTO trunk. The bottle will suspend from the air giving you full use of your trunk space.
ONLY 99.00
http://www.nitrousoutlet.com/catalog...roduct_id=2143
I will be adding a great deal of other parts to this post. Pay close attention because the rest of the parts have limited supplies for the special price.
Let me know if I can answer any questions.
Grant
Old Feb 16, 2009 | 11:29 AM
Nitro Dave's Avatar
We have extended our sale untill Wednesday. We will be closed Thursday and Friday to move.
Dave
Old Feb 16, 2009 | 04:36 PM
CrashnBurn's Avatar
Dave....not sure about the sale right now...but Moe Bailey did my tune and said you were the man to talk to about puttin a 150 shot on my car.....need ideas for kits....pms would be fine
Old Feb 17, 2009 | 07:08 PM
jakesz28's Avatar
The good sales always happen when I'm broke.
The brand x bottles how much hp do you think the valve will support? I will be spraying up to 400hp and would like to try and do it with one bottle but do to the pressure drop I may just go with 2 10lb bottles a pass.
To make a long story short I need to order about 6 bottle before the shootout.
Old Feb 17, 2009 | 11:27 PM
Nitro Dave's Avatar
The brand X bottles will support up to 800 hp. The valve will flow plenty. They just do not have accessory ports. I have 3 blue bottles I will let you have for a 100 each.
Dave
Old Feb 17, 2009 | 11:29 PM
Nitro Dave's Avatar
Sure. Shoot me a pm with what all is done to your car and I will bounce some things off of you.
Dave
Old Feb 18, 2009 | 05:17 PM
jakesz28's Avatar
Dave
Your really tempting me but I have to see what happens at work. I lost all overtime two weeks ago and yesterday they put me on 32 hours. Not good but we already laid off about 30% of the employees at this point I'm still glad I'm working.
Now on the brand x bottles have you actually tested the pressure drop while spraying 350-400hp thru a 6an hose? Your giving me some hope. I was considering a 8an hose and the bottle in the passenger seat(to shorten the line) but pressure drop with one bottle and a standard style valve is what has me concerned. I've seen most of the newer stuff is going to a 45* valve to help with pressure drop and then there is the NX ball valve style bottle that I've consided but there just a little pricey. What size pick up tube is in the bottle?
alex5366
Feb 17, 2015 10:43 PM
Dec 17, 2014 11:00 AM
ChrisFrez
Dec 7, 2014 06:01 PM
Dec 4, 2014 11:56 AM
NewsBot
Dec 3, 2014 12:30 PM
