How much timing to pull while spraying??
Old Nov 17, 2003 | 07:50 PM
snksknr94's Avatar
I remember reading somewhere that there was a certain amount of timing to pull per 25 hp or so. I just don't remember what the ratio was.
Thanks!
Old Nov 17, 2003 | 10:12 PM
Fuels94TA's Avatar
Re: How much timing to pull while spraying??
Thanks!
If I remember it's 1-2 degrees for every 50hp.
Vinny
Old Nov 18, 2003 | 10:53 AM
Speed Inc.'s Avatar
I have tried a few things.
yes as mentioned above 1-2 degrees per 50hp is the norm.
I originally pulled 6 degrees and now pull 10 degress with a 250 shot. We have found that by pulling more timing showed no loss in MPH or ET and therefore is safer. I showed no signs of any detonation or knock either with only 6 degrees.
I would try pulling more timing then you normally do and see what happens.
why not run it safer and not lose any ET or MPH
I run 31-32 degrees total with a 12.1 383 LT1 and 110 octane(N20) 93 octane N/A
hope this helps
Larry
Old Nov 18, 2003 | 12:04 PM
262guy?'s Avatar
I was wondering how long it takes for that 110 to kill the oxygen sensors.
Old Nov 18, 2003 | 02:17 PM
Speed Inc.'s Avatar
The 110 does not damage my 02's because I don't run any 02's
We run my car in an open loop program,and it works out very nicely.
Larry
Old Nov 18, 2003 | 05:36 PM
Brandon 95 Z28's Avatar
What size shot are you planning on running at the track Aaron?? I think 4 degrees would be safe for the 100 shot.
Brandon
Fatdog2
Feb 13, 2015 08:19 PM
David Dorris
Jan 17, 2015 08:10 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
